Truck manifold turbo people...please step inside
Old 06-25-2010 | 03:45 PM
evo462's Avatar
Default Truck manifold turbo people...please step inside
I plan to do a truck manifold turbo install And had a question for those of you with this setup. Did you remove your swaybar to make room for the downpipe or did you run your piping around it? If you left the swaybar on, how did you route the downpipe? Under the swaybar then back over the k member? If you took off the swaybar, how did it affect your handling or the ability to make a quick (emergency) turn? Its mainly a street car and I am already going to be giving up my favorite creature comfort (A/C) and am not sure about the swaybar thing
Thanks!
Old 06-25-2010 | 08:36 PM
WS6HUMMER's Avatar
Thanks!
I didn't give up AC but have a truck manifold on 1 side, the side with my 4" DP. I took the sway bar off way before I ever knew I would add a turbo. I could tell the sway bar wasn't there but later added SFC's, then a Wolfe anti roll bar, then a Wolfe 6 point roll bar, & all of the above gave me WAY more rigidity than stock with the sway bar still on.
Old 06-25-2010 | 10:19 PM
98Z28CobraKiller's Avatar
Restricted User
Are you road racing?
Old 06-26-2010 | 09:16 AM
smokinHawk's Avatar
I got a 4" dp and have it go over my sway bar
Old 06-26-2010 | 01:34 PM
XtremeDime's Avatar
How do you have the crossover pipe setup that you have to worry about the DP hitting the sway bar? Seems like the turbo would be mounted too low..
Old 06-26-2010 | 03:04 PM
smokinHawk's Avatar
I have some pics here
https://ls1tech.com/forums/forced-in...t-up-faqs.html
cross over loops under the sway bar on one side though
Old 06-26-2010 | 05:10 PM
elias_799's Avatar
you can try spacing it down a little to give you more clearance
Old 06-26-2010 | 06:02 PM
transammiller's Avatar
Restricted User
i dont think hes referring to the downpipe. i think he means the crossover pipe.
Old 06-26-2010 | 06:06 PM
XtremeDime's Avatar
Oh that makes more sense. I just bought a truck manifold kit...I hope it clears the sway bar since Ill be autocrossing it...
