Why no Kenne Bells?
Yeah I forgot about that. That will factor in quite a bit depending on what AWIC they used under the blower. Everything else can be modified to provide lower IAT's.
I will have to take a look at some of my datalogs and see what IAT's I was hitting after going WOT and also cruising.
FWIW, the entire kit DOES need re-engineering. The blower needs to be turned around, and use a jack shaft setup, so you can mount the TB in the front. The IC/intake mani needs redesigned BAD! For the right money it could be made to make crazy power, but it would take an open wallet to do it.
I agree with you but I still have the tune by email from him, That he had on his old car. Which was almost the same as my build but I just had a little more cam than what he had in his. IAT SPARK TABLE all zero out. That is why I pulled the kenne bell from my car. Way to much problems with a head cam set up to get the unit to do the rwhp that JEFF says the unit will do. Just a bad intake for the corvettes. We will see what this new intake and set up will do on the corvette. https://ls1tech.com/forums/picture.p...&pictureid=735
I guess some like that but I am looking to get to the end of the track 1st.
The kenne bell looks good on top of the motor. BLING for sure.... Last edited by kbracing96; Jun 30, 2010 at 03:15 PM.
http://www.challengertalk.com/forums...648rwhp-40317/
I can say HEMI
But still a nice looking car. http://www.challengertalk.com/forums...648rwhp-40317/
Thanks
They suck. The end.
I wouldn't call the T/S a better design over the roots, it's just different and has its own pros/cons. For all the talk about efficiency on the T/S they seem to produce a lot of heat.
The twin screw is great for mid range, fast response and extremely forgiving powerband. However, the turbo and the centri will dog it on the big end. They are very popular for cobras and such because they are basically bolt on replacements. They have their place, but they are not the best all out performers you could get.
My TVS 2300 is pretty boring. It just runs hard with no drama. I know it's limited to around 750 rwhp before belt slip and high IAT's put a damper on things. Happy with what I have though. 670+rwhp in a 3200# vette is a whole bunch of entertainment
Data from my 2300 08Z06
fourth run of the day
10.56/137.82@3447 da. Driving up in the staging lanes and started run 12*C hotter than normally see.
Start of burnout 55C [131F]
Max 67C [153F]
91 fuel-no meth-10.5:1
An absolute ball to drive on the street and iats stay around 15-17F above ambient at the speed limit. Heavy traffic iats are about 3x*F above ambient.
'Supersub' has info on better cooling.
Gearset needed to operate in the right rotation then
eewwwww i have to take an angle grinder to my hood and buzz off 1/16th of an inch???? uuuuhhhggggg resale isnt gonna be that good because i altered the integral structure of the hood... eeewwwww....
-TNT spec (me) = if you're buying something as gnarlly as the KB blower,,, you WANT to make real power and will take whatever steps required to make it happen. Whereas the certain folk cant grasp that concept...
****, i cut and boxed my frame rails to make my 88mm fit in my ls1/rx7. Some people (alot) get all pissy over poeople installing a v8 in these cars let alone "butchering" the frame. lol --PS no rotary is gonna beat me on pump fuel, just saying...
-end rant/truth.
