round 2 new build, pics page 2(s85,th400,370ci,9")
i understand that. just trying to help you get it up and running faster but hell 5 hr is not going to make or brake you. good luck man i cant wait to see this thing run.
oh and any world on the turbo blanket?
Good news...... Pick the Motor up yesterday from kurt, gotta go back there when my pushrods come in and he also has to modify my tci flexplate.
Picked my Whip up from Stenod, Cage looks amazing. gonna start on sanding and painting the engine bay later today after work.
Will be posting pic's finally later also
Ill be shooting pics of the car tomorrow need to pick up a new camera
im hoping to get the car up and running by my birthday aug 18th
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
You are really going to want gears. I run a 3.46 gear with my TH400 in my GTO with 26" tires. Freeway speeds here are 65mph-75mph posted, so I'm at 3500-4000+ trying to go with the flow. Plus turbo's like load, so dropping down numerically will make that thing pull like a beast.
Do you have room to mount a quick spool valve in there? If it doesn't spool how you like with the 1.32.
http://www.sound-performance.com/
Edit: Just realized they want $500 for a spool valve. It's probably cheaper to just change housings.
gonna be running a 28" tall tire eventually and switch to a 3.25 gear. if i have spool issues ill spray the car
At least your gears don't cost $600 like mine do. I'm gonna switch them and it kills me I have to pay that much. Plus an install kit and labor. Gonna be $1k for new gears. Then I may as well put in a True Trac while I'm in there. There goes another $550. Needless to say gears will come next year.
got a little work done in this humid weather, ran into an issue tho
with the turbo blanket on i cant fit the water pump on(hitting the snout)so got 2 options run it without the blanket which i think ill have over heating issues due to how big this thing is an limited spacing between radiator and turbo. OR buy an ls2 waterpump or meziere pump
. just when you think ur done spending money lol.
oh ya the camera i borrowed took a **** also lol so looks like ill have to fork out money for a camera also
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
cage got its first coat of paint today, por-15 is a pain in the ***.
ran into another issue with size of turbo its also hitting the power steering pulley....
reclocked turbo still doesnt clear it geezzzz. so do they make a small powersteering pulley for are cars? open for suggestions
#32
ya ill be picking one up monday so that problem is now solved.
my new issue is the powersteering pulley hitting the turbo, the clocked the turbo as much as the can but still hits it. dont know what to do now![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
has anybody seen shearers pulley kit? its not on his website and i cant find anybody else who makes a power steering kit, or even a small pulley
I need about 1/2 inch to clear it
#36
Restricted User
#37
Just curious how you plan on routing your down pipe over the k member. You mentioned that you have all UMI front suspension, so I would assume you have a UMI kmember. I have the same kmember and am going to run 6.0 manifolds as well, but I dont see any way to fit a down pipe around the UMI k member unless I run somthing like 3-3.5''. I was planning on selling my k member and buying a bmr turbo k member.
#38
my downpipe is 5"inches and is only 16"long dumps right to the ground, ill gonna try to post some pics when i get home from work if it lets me.
#39
I think Josh had Shearer make a few for him. Hit him up. It's just a bracket that moves the ps pump in tighter to the motor (side to side). It's a nice piece and the that Steve got for his car has worked out great so far. Not sure if that is where you need the space though without seeing a picture.
I talked to kurt today ill be picking up my pushrods and my flexplate that he modifys from tci tomorrow and droping back off the motor and turbo hotside for him to fab up a bracket for the powersteering just gonna cost me 75 bucks an hour in labor
