sdce vs aster
Old Jul 5, 2010 | 08:03 PM
CyaPussy's Avatar
Default sdce vs aster
Anyone actually ever try both of these setups just looking for input. Like to here the good and bad about both if possible.
Old Jul 5, 2010 | 08:59 PM
Inspector12's Avatar
TT-TECH Veteran
Yeah I have both! I can tell you that Aster's bracket has way more belt wrap than the SDCE setup. I did have a few belt alighnment issues I went through about 5-6 belts before I got it right and it seems to be working great. Although you are only running a D1 so either one will suit your needs. The F series blowers really put a lot of stress on belts which makes it that much more critical. The D1 is no problem to max out with either set up. GL!
Old Jul 6, 2010 | 07:24 PM
kkslds's Avatar
Yea both setups look nice.
Also I believe Aster's bracket allows for a 7.65 crank pulley without having to swap to a ls3 waterpump.
I have a sdce and so far so good. Haven't put many miles on it yet, but it's a huge improvement over the procharger 8 rib kit.
Old Jul 6, 2010 | 07:27 PM
Aster's Avatar
To be fair my setup does require the 05+ Corvette waterpump. I'll avoid making comparisons here though since the OP is looking for input from users.
Old Jul 7, 2010 | 01:12 AM
Ryan33187's Avatar
What is the cost difference between the sdce vs asters?
Old Jul 7, 2010 | 01:21 AM
98legendws6's Avatar
i believe they are the same price. However with Asters bracket you have to also get the Corvette H2O Pump. You could of saved almost 100 on the SDCE on the GP but i think it just ended.
Old Jul 7, 2010 | 01:28 AM
SilverSS's Avatar
I've never had SDCE but I do have Aster's. It's great and spins my F1A without problems. Before this, I had the standard 8 rib set-up with the extra idler mod. Aster's is worlds better compared to that since the belt doesn't have to be super tight all the time causing unnecessary wear.
Old Jul 7, 2010 | 11:49 AM
94 slow's Avatar
Aster,
What kind of power are you putting down with your 383 and D1?
Old Jul 7, 2010 | 12:15 PM
Aster's Avatar
Originally Posted by 94 slow
Aster,
With a 3.85" head unit pulley it was making 13 psi and 675/605, through full exhaust, two cats, and two mufflers. I figured it was pretty decent given the pulley size and exhaust.
Dyno pic can be seen here.
I had since pulled the cats off and never got it back on the dyno. I expect it was close to 700. Then I found out my ring gap had been set to tight by the builder and one of them lifted and pealed half the piston off.
I'm currently rebuilding it with Wiseco pistons and a wider gap. I'm considering dropping the pulley size a little to see what it will make on 15 psi. I didn't do the 3.4" because the last had unit I had (a used P1) died on the dyno with it, and I was trying to avoid pushing too far on my street car. Lessons learned, stuff will break anyway and always double check someone else's work.
Old Jul 7, 2010 | 01:55 PM
LS1RedZ's Avatar
With the SDCE setup do you have to buy a bracket and send it to them? If thats the case then the 2 kits are about the same in price.
Old Jul 7, 2010 | 03:49 PM
conan's Avatar
I've never had any belt slip with my SDCE, well worth the money. Aster's tensioner looks sweet as well. I don't think you'll be disappointed either way you go.
Old Jul 7, 2010 | 03:53 PM
youngrigo's Avatar
More than likely if you going with the SDCE you probably already have a stock J-Braket and thats what you send to them...
Aster's Bracket i beleive is a New bracket so in essense you can sell the stock one....
Old Jul 23, 2010 | 10:15 AM
9t8z28's Avatar
SDCE is a vendor here?
Old Jul 23, 2010 | 10:33 AM
cals400ex's Avatar
i think they are paying members just when they want to run a GP but i am not 100% sure.
Old Jul 23, 2010 | 10:49 AM
sixpack_2_go's Avatar
sorry to hijack, but is the lsxsolutions tensioner the same as the aster? i've done a search and looked everywhere but i can't find any info on the lsxsolutions tensioners.
Old Jul 23, 2010 | 12:22 PM
MadIceV8's Avatar
Customizing Director
I believe so. Just another outlet to sell it through.
