Electronic Boost Control systems... what are you using?
Old Jul 6, 2010 | 09:46 AM
ZGOBYBY's Avatar
Default Electronic Boost Control systems... what are you using?
What electronic boost control systems are you guys using? I am searching for some online, and was curious to see what everyone on here is having success with. Much thanks!
Old Jul 6, 2010 | 11:32 AM
MECHAM's Avatar
Eboost 1
Old Jul 6, 2010 | 11:51 AM
Phil99vette's Avatar
7 Second Club
ams 1000
Old Jul 6, 2010 | 11:56 AM
F8L GTO's Avatar
interested as well!
Old Jul 6, 2010 | 01:05 PM
ZGOBYBY's Avatar
Originally Posted by MECHAM
Eboost 1
Looks like E-Boost 1 isn't really on the market anymore, but I see E-Boost 2 is. Pretty pricey, but a lot of people say really good stuff about it.
Anything else out there that you guys have had success with?
Old Jul 6, 2010 | 01:18 PM
cracker's Avatar
EBoost II
Old Jul 6, 2010 | 05:28 PM
koolrayz's Avatar
AMS 1000, The ams500 is also good
Old Jul 6, 2010 | 09:03 PM
jason02Z's Avatar
AMS 500 works great hard line and no c02
Old Jul 7, 2010 | 11:16 AM
bad6as's Avatar
just bought an ams-500 for mine
Old Jul 7, 2010 | 11:23 AM
euroman's Avatar
exile boost controller -no problems
Old Jul 7, 2010 | 01:30 PM
Fireball's Avatar
Ams1000
Old Jul 7, 2010 | 03:08 PM
Super Slow SS's Avatar
I have the aem truBoost .. although it is just a gauge right now, it wont get hooked up to the solenoid until Monday when its time for a retune and more boost
Old Jul 8, 2010 | 04:00 PM
elias_799's Avatar
i have a aem trueboost, it took me a while to figure out how to set it up but after i did it worked pretty well
Old Jul 8, 2010 | 05:46 PM
98Z28CobraKiller's Avatar
Restricted User
AMS500 + CO2.
+ Very accurate and super simple.
- Mounts under the hood and no cool display.
Have also worked with the AMS1000
+ Most accurate boost controller available, mounts in the car, has cool display, does everything and then some.
- You gotta read the manual because it does everything and then some. LOL
Nobody elses support is in the same ballpark either.
Old Jul 8, 2010 | 08:41 PM
Turbo 6.0's Avatar
Sts ebc-15
Old Jul 8, 2010 | 09:06 PM
Dogsofjune's Avatar
Same here.
Old Jul 8, 2010 | 09:44 PM
mightyquickz28's Avatar
AEM TruBoost here. It has the the 'defined' "A" mode, "B" mode and "scramble". You set the boost for "A" say for 12psi, then "B" for say 14psi and have "Scramble" set for perhaps 16Psi. You toggle (pressing the two provided buttons simultaneously) between "A", "B" or Off (running right off the spring then). You hook up a momentary 12v switch/button to enable the "Scramble" (so you can finish the kill on the guy that is just squeaking past you) It fits neatly into my two pod pillar right above my Wide Band AFR gauge.
Old Jul 8, 2010 | 10:49 PM
MY99TAWS6's Avatar
Eboost 2 .Perfect fit in center air vents.
