Need help deciding on method for reducing CR
Old Jan 19, 2004 | 11:11 AM
Shinobi'sZ's Avatar
Question Need help deciding on method for reducing CR
I need some help deciding whether or not to pull my heads off and sell them and buy some AFR 76cc heads or remove some more material and make my existing 72cc LS6 Heads, 75cc and O ring them for use with Cometic Gaskets.
My CR is 9.67:1 right now and I would like to lower it. The motor already has -2cc Forged Diamond Pistons and Lunati Pro Billet Forged Rods. ARP Head Studs too.
I would like some opinions about either modifying my existing heads or selling them outright and buying the new AFR Heads.
If I keep my heads and hog them out some more (least expensive), I plan on O ringing them and using a Cometic Gasket.
My deck height is .014 so what thickness Cometic Gasket should I use? I would like to go as thick as possible without screwing up the quench.
I have calculated my CR to be 9:1 if I hog my existing heads out to 75ccs and use a .060 crushed head gasket.
Thanks
Kevin
Old Jan 19, 2004 | 11:19 AM
blackz93's Avatar
i guess that would give you .046 quench which is ok i guess. assuming that its .014 out of the hole.
Old Jan 19, 2004 | 11:37 AM
smokinHawk's Avatar
you cant use a MLS gasket with a o-ring. people either use copper or a graphite gasket.
Old Jan 20, 2004 | 05:14 AM
SS00Blue's Avatar
.014 OUT of the hole?!? I HOPE he meant in the hole!
SC-
Old Jan 20, 2004 | 05:31 AM
y2khawk's Avatar
what's wrong with .014 out? production is .006 out.
Can you even get AFR's yet?
Old Jan 20, 2004 | 10:22 AM
blackz93's Avatar
exactly...
Old Jan 20, 2004 | 12:05 PM
Shinobi'sZ's Avatar
exactly...
It depends I have seen it vary (deck height) between .006-.009 from the factory. Also it depends on your Rod and Piston Combo. My 6.125" rods for a 3.622 stroke and Diamond 3.905 Pistons along with a .004 resurface of the block left my deck height at .014 out of the hole! So I should be able to use a thicker head gasket.
Old Jan 20, 2004 | 03:04 PM
MYTURBOT/A's Avatar
The AFR street 205cc heads are supposedly ready for delivery.
