breaking up around 5k HELP PLEASE
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
It could be valve float, I just don't know how to diagnose it or what to look for.It has a hot cam, shims rocker and springs that came with the kit. Broken spring? The car ran perfect before it blew a head gasket at the track.
It's only getting around 5psi when this occurs
Could you Please describe valve float
LS1Tech Sponsor
The first thing and cheapest to do would be to replace the new sparkplugs with another set just to make sure you didn't get a bad plug. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
I was feeling lucky and set my 100kpa in the extended timing tables to be around 20* at 6000 and added 20% more fuel as well, no change.
You think I should try another set of plugs? When I put my engine back in I installed new plugs, now anogher set, the engine now has around 1000 miles on it.
Could someone describe valve float for me and what will fix it?
thanks guys
I Have found something... this spring after my rebuild I had some valves that somehow became bad, they were fine when the head gasket blew but became bad from the time it blew and when I put the engine back in. well two of the valves look to be shorter. from the top of the retainer to the top of the valve stem, their is a difference. My caliper has a flat surface on the end and a small rod will extend out, the two valves are around .025in shorter and the valves have rubbed into my roller rockers. I don't know if they became loose (seemed loose even for roller rockers) or if this difference in length makes a difference, well I know it makes a difference.
Now I need to either readjust the valves, give it a try or just get the correct valves or send them off to Loyd or AI.
Am I correct that since the valve is shorter than it is supposed to be than the angle of the rocker will be off regardless if it's adjusted properly?
If this is the problem and if it's valve float, you don't ever want to encounter it, it sends chills throughout your body!
What do you think???
I reajusted them and have the same issue. I noticed on one of the rockers it looks like the pushrod has left an indention in the rocker.
Any advise all I know to do now is put the proper(or I think) proper valves back in I just don't want to burn any more time and money for nothing.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
I installed some new valve springs that have 130# closed pressure and are good to .600 lift, put some different rockers, it still does it. I really don't have any other Idea what to check or do. I just don't understand why it does it under boost, and not if it freely revs to 6k. sounds like a loose rocker and the engine goes haywire. Anybody,
I had problem like this several times. Each time it turned out to be wires. Burnt or not connected or defective. I know wires are not fun in the lt1 but that is likley the problem.
If you plugs are good its likely wires. If you can run misfire checks on scanner then likely see which cylinder pretty quickly.
well I have not replaced the plug wires, their not that old and have all checked out ok with no burns.
I now either need to just sale the car or keep on, I'm looking to getting a wideband but I noticed as soon as it breaks up my injector pulse goes down to 8ms or pulses per second, whatever it is(can't remember)
I thought my bypass valve was opening so I blocked it off and it still does it.
Do I need more fuel pressure? I've got the stock pump with the procharger inline pump
I don't know much about the LT motors but I do see a number of comments about opti ignition problems. You might run this by the gang at CamaroZ28.com There seems to be a bunch of LT version owners there. You might need to put the car on a chassis dyno to locate the problem? Don't give up.
sounds to me like a bad opti. pull the cover & check your rotor & contact points. also common for the bearing to go bad which will cause spark issues @ higher rpms due to vibration.
Thanks guys
Well I thought that and have already installed a ebay opti, which never really worked right, now I have a brand new delphi opti and cap. So what are my options now?? and possible problems
bad new delphi opti
going lean with proper fuel pressure maybee a bad fuel pressure gauge? so the fix would be bigger fuel pumps.
Bad tune?
plug wires
bad new fuel filter
inlet colapsing?
All I know is it did not do this before I blew a head gasket and broke some pistons. took the block heads crank rods and new pistons to machine shop, they cleaned up the heads said they were fine(later to find out two valves somehow went bad from the time it blew to when I put them on) polished stock crank, My concern now is if they missed the valves, could they have messed up on ballancing. they did not get my flywheel.
bad new delphi opti
Bad tune?
plug wires
bad new fuel filter
inlet colapsing?
