Holsets good to 200+lbs boost
Last weekend NTPA had their tractor pull nationals where i live. Up to 4 turbos on the tractors and the announcer said they push 200 psi or more
So i of course go to the pits and ask around what turbos they're running and what they do for iat's. I suspected some huge custom billet turbos... but was dead wrong lol. One guy had 4 holsets on his IH, said they where like H5?? don't remember exactly what he said. Two headers off the motor, each one going to 2 turbo's in the standared compound fashion. It blew my mind that these turbos that you can get off ebay can make that much boost!
For air temps he's running 22 nozzles and going through 3 gallons of water in 320 feet
and around 4 gallons of diesel
I know its not lsx related but pretty cool nonetheless
Dyno vid at 60-70 psi
http://www.relentlessdiesel.com/medi...C%201132HP.wmv
Track video
http://www.relentlessdiesel.com/medi...0atbaytown.wmv
Add more air on a gas motor without adding fuel and you'll 1st raise the combustion temps, then start losing power because there isn't enough fuel. Do the same to a diesel and all you get is cooler combustion temps and less soot.
The do work the same in their function of adding more air to the mixture, but it serves different purposes.
But seriously you should go read up on diesels more. for one soot is to much fool aka not enough air and yeah egt's are higher when running richer in a diesel as your not burning the fuel. So this means it goes straight through the engine and into the exhaust hence soot/smoke.
I'm not going to continue to explain how wrong you are in thinking boost cools ****.
HAHA boost doesn't make power it cools.
What about putting 200HP worth of n2o on a stock diesel with no additional fuel, will you gain close to 200 hp? Will it blow up?
What happens if you blow 300 degree air into 1600 degree air, will the 1600 degree air get hotter?
What happens to the temperature if you keep adding more diesel to the combustion process without supplying more oxygen?
How do you correct what happens?
How do you throttle the power a diesel engine makes, do you vary the amount of air coming in with a throttle body or the amount of fuel (air fuel ratio).
What is the operating air fuel ratio range of a diesel at idle and WOT?
Feel free to continue taking my original post out of the context I intended, but only after answering the questions I just asked.
Adding air with out fuel will not add power to a diesel.
If you keep adding fuel with out adding air you will get smoke (not burning all your fuel and egt's will start going up).
Diesels are contolled by the injection pump and the amount of fuel that is added to the engine, NOT by controlling air flow with a throttle body like a gas motor.
Diesels dont have a operating AFR. If you add too much fuel and dont have enough air to burn it you start blowing black smoke which is not a good thing since its fuel being wasted and it makes you EGT's go sky high.
If your blowing 300 degree air into 1600 degree air of course its going to lower your overall temp.
I think every one is on the same page here. We are just trying to say the same things diffrent ways.
Maybe just saying it cools and just leaving at that left it too open. The added air is used to lean out the mixture to keep the combustion process under control. If the combustion process is running too hot due to being too rich, you add more air (boost in this discussion) to cool it off and make more power through a more complete burn.
Running high boost on a diesel vs running high boost on a gas motor are very different scenarios. They both need the extra air, but for different reasons.
Diesel: Add air to match your fuel, power regulated by amount of fuel delivered.
Gas: Add fuel to match your air, power regualted by amount of air delivered.
Zombie seems to know whats going on, as does cbr600. To shut off a diesel all you need to do is stop air from entering the motor. Add power by simply turning up the injector pump (already tore out a planetary on a little 7710 ford lol). I would THINK adding air will allow you to burn more fuel, simply put.
I'm no expert on diesel combustion, but i guarantee i've put more hours in them than all you lol.
