Possible causes of seized PT88...?
You'd have to weld the hole shut for the air cleaner stud, find a piece of silicone hose to attach it, etc... It's 100% easier to just buy a new air filter/rubber elbow
The inlet on my turbo is a little tight to the frame. Not alot of filter options for me. I'm going to have to duct in some air from in the fender or bumper cover.
It's hard to see but the frame rail is almost right up against the filter. Just enough room to slip it on.
Now I see what you were saying... I still think the point about having to have a rubber cuppler stands. How are you going to attack that?
I also think something like that would be SERIOUSLY restrictive compared to what you have now.
A 5% increase in your engine size over what they designed the turbo for should not cause a turbo to sieze.
That is a pretty small margin of error - especially in the hot-rod world where every setup is very different.
