Possible causes of seized PT88...?
Old Aug 10, 2010 | 08:37 PM
camaro383's Avatar
Originally Posted by cjg454ss
i had mine over a year and a bunch of passes. in the end...they said oil starvation. its a junk turbo.
lol, i hope its good now cause im running your old turbo and pipes on my 370 right now, about 100 miles and about 15 9psi passes, however i had to raise the turbo 1" cause i was having some oil drain problems under WOT so hope that was part of your problem
Old Aug 11, 2010 | 12:03 AM
Snyper's Avatar
My cars never smoked or anything...
Old Aug 11, 2010 | 01:41 AM
00bluews6's Avatar
i love how everyone says they are junk maybe there set up was just junk if you cant help don't chime in
snyper i hope u can get some help or reasoning for this to happen it Precision should have the answer
Old Aug 11, 2010 | 01:51 AM
Snyper's Avatar
Ill be pretty pissed if they blame it on me. I bought everything recommended by and from one of their vendors...
Old Aug 11, 2010 | 04:17 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I'll be interested to see what they have to say about it. It is interesting it completely froze up like that without any contact.
Old Aug 11, 2010 | 07:02 AM
camaro383's Avatar
Ya ill be pretty upset if mine freezes up, i ran a 1/8" (.125") restrictor for that 100 miles cause i had smoking problems with the -4 fitting but since i raised the turbo1" i put the -4 fitting back on.....i guess ill be calling dr.turbo for a rebuild and a 91 upgraded compressor if i have any problems, btw anyone know what he charges for the 91 uprade
Old Aug 11, 2010 | 09:00 AM
DrTurbo's Avatar
LS1TECH Sponsor
The upgrade is 699. Unit will make about 100-150+rwhp more depending on your setup.
Old Aug 11, 2010 | 09:23 AM
dschmittie1's Avatar
I will keep that in mind if I have any issues with my PT88
Old Aug 11, 2010 | 10:59 AM
cjg454ss's Avatar
you got a brand new turbo if i remember correctly. they fixed the old one a bunch of times and it didnt work right so i got a new one from them. glad its running good.
ps, i had a good pcv setup with a ton of pull up top. i think that helps with the draining.
Old Aug 11, 2010 | 11:26 AM
Snyper's Avatar
Well if they dont warranty it its going to you. Would the price be the same for my seized up turbo? Like I said..no contact on either side..just frozen.
Old Aug 11, 2010 | 12:25 PM
camaro383's Avatar
I vented the rear of the drivers side valve cover
The ls6 valley cover
And the two barb fittings on the driver side as well as the oil cap open with a filter on top
Maybe i shoulda hooked it up the the inlet of the turbo to pull a vacuum on it under boost, but i figured venting it would be good enough...
Anyways, thats an awsome deal for the 91 setup, but hopefully precision repairs your turbo for free
Old Aug 11, 2010 | 03:12 PM
  #32
DrTurbo's Avatar
LS1TECH Sponsor
More then likely the backplate collar and backplate itself have fused together. PTE should take care of it.
Old Aug 11, 2010 | 04:37 PM
  #33
98Z28CobraKiller's Avatar
Restricted User
You talking about the exh side (iron) or intake (aluminum)? I don't know the name of the parts, just what they look like. I had to replace the shield looking thing that goes between the turbine/shaft and the center cartridge thing. The old one was falling apart and loosing little tiny pieces that hit a couple of the turbine blades on the way out.
Old Aug 11, 2010 | 06:28 PM
  #34
DrTurbo's Avatar
LS1TECH Sponsor
The exhaust side is the dust/heat shield. I was talking about the aluminum/intake side. Yeah the heat shield will corrode with time......with an alky motor it real gets killed quick due to so much water.
Old Aug 11, 2010 | 06:35 PM
  #35
Snyper's Avatar
DrTurbo..do you have any pics of the 91mm upgrade? I might send it to you anyways to have the upgrade done. Would my LS2 be capable of 1000whp with this mod done to the turbo?
Old Aug 12, 2010 | 11:58 AM
  #36
DrTurbo's Avatar
LS1TECH Sponsor
Yes it would.....
The pics are in this link.....
https://ls1tech.com/forums/forced-in...ally-home.html
https://ls1tech.com/forums/forced-in...ick-treat.html
Dyno data from the two on the same car.....
https://ls1tech.com/forums/13383596-post12.html
https://ls1tech.com/forums/13380470-post1.html
Car went from 821 to 961rwhp....rear mounted.
Old Aug 12, 2010 | 12:07 PM
  #37
Snyper's Avatar
I notice it has a 5" inlet but no surge housing, just empty space. Would it be possible to get it with a 4" inlet so I could fit my filter on it??
Old Aug 12, 2010 | 12:52 PM
  #38
ryarbrough's Avatar
I think MIGHTYMOUSE inquired about that. He was told there wasn't enough material to machine the 5" inlet down to a 4" inlet IIRC.
Old Aug 12, 2010 | 03:52 PM
  #39
Snyper's Avatar
Maybe the use of a different cover?
Old Aug 12, 2010 | 04:47 PM
  #40
ryarbrough's Avatar
From my understanding there was no other cover when David converted over (or he would have used it). I'd PM him/Jose and confirm that and see if anything has changed since.
