My Precision 76mm turbo build
Out of the turbo yes, to a straight, and then a 45* to the pan. Usually I run the turbo drain straight down, but I think it will be fine like that. Gravity should still push it. If I have any smoking I will make it straight and add a 45* fitting out of the turbo.
Have all the cold side welded up now, didnt get a chance to do the BOV.
Started running the engine harness, I was extending the coil wires here.
#37
Thanks man. Heres a shot of the BOV, and the IAT sensor.
I ordered a muffler and some other things from Vibrant but they are lagging. I need the muffler to show up to finish up the hot side.
