My Precision 76mm turbo build
Old 09-04-2010, 07:06 AM
  #41
speedster94's Avatar
Very nice build you have here. Lots of great fabrication. Can't wait to see it run !
Old 09-05-2010, 03:05 PM
  #42
Greg@RET's Avatar
Thanks, should run mid to high 6's in the 1/8 mi. Good enough for a street car.
Old 09-05-2010, 03:33 PM
  #43
KILLER-LS1's Avatar
It was cool seeing this car the other day! cant wait to see it run! Let me know when you guys head out to irwindale next, i still need to get mine out there
Old 09-05-2010, 07:41 PM
  #44
00SS4780's Avatar
Sweet build. Can't wait to see the end result!!!
Old 09-06-2010, 11:19 AM
  #45
2002SLPSSCAMARO's Avatar
where did u get the cage...and how much was it...without the powder coat??
Old 09-06-2010, 12:55 PM
  #46
Greg@RET's Avatar
Thanks guys, I am getting excited about seeing the end result also.
We built the cage here, we would charge about $2500 to build another one. That includes installation. Wouldnt make a mail order one since there isn't a jig for it.
Old 09-14-2010, 07:36 PM
  #47
Engine_HP's Avatar
looking good keep us up todate
Old 09-14-2010, 09:56 PM
  #48
smooth01's Avatar
Whats up with the steam vents on the back and front of the motor.
Is it for air pockets or to improve cooling?
Old 09-20-2010, 12:41 PM
  #49
Greg@RET's Avatar
Yes, well mainly so there is no air in the system. I mounted the block on the cowl so that will be my bleeding point. Havent been able to work on the car much lately, but will get a couple pics up.
Old 09-20-2010, 01:25 PM
  #50
CarsandWomen's Avatar
any update on this? been a few weeks since we had one
Old 09-22-2010, 09:17 PM
  #51
Greg@RET's Avatar
Sorry, shop has been busy even with four employees its hard for me to find the time to work on it.
All the cold side is currently at the coaters... it will be the same color as the car.
Here's a shot of my vacuum distribution block/lines
-20 coolant lines/fittings
Power steering set up/lines, over flow catch can, and brakes (still need to finish)
Started bolting up the lights...
Mikes transmission called and said the trans is ready to pick up. So now I just need to get out there.
Old 09-23-2010, 12:01 AM
  #52
BottleFedZ346's Avatar
Wow very nice if mine turns out to be half as nice as yours ill be happy!
Old 09-27-2010, 11:34 AM
  #53
Greg@RET's Avatar
Thanks man!
Heres a shot of the intake coated.
Old 09-28-2010, 09:20 PM
  #54
Tzion_ben_Arthur's Avatar
Is that an ac cond and compressor? Is this build going to have AC? Sweet!
Old 09-28-2010, 09:50 PM
  #55
boostedgtp's Avatar
Looks badass, what are you doing about an alternator.
Old 09-29-2010, 02:56 PM
  #56
Greg@RET's Avatar
Yep, has to have a/c
It will go by the passenger side head, just need to make the bracket.
Old 09-30-2010, 11:01 PM
  #57
Greg@RET's Avatar
Only progress lately is bolting a filter on lol
Old 09-30-2010, 11:24 PM
  #58
Deff. one of the nicest setups on here!!!!
Old 10-01-2010, 05:14 PM
  #59
ReApEr75's Avatar
Wow man, attention to detail is crazy. Welds are bad *** too. Very nice and clean build. I don't know if you said this or not but im just curious, where you getting your black coolant, oil, and other lines from?
Old 10-02-2010, 07:37 AM
  #60
badmfkr's Avatar
Default very nice
Originally Posted by Greg@RET
Thanks man!
very cool, clean build. engine bay looks brand new.
dig the fuel line an FP mount very cool. ? how doe's the fuel line connect to the rail?
I see the exhaust out the fender. why did'nt you use the ebay down pipe for a street car?
doe's the motor torque any w/ soild mounts (Move like with rubber mounts) just curious w/ you'r connectorless
cold pipe if rubber mounts where used would the MAF crack due to motor movement?
I like the cold side won't ever have to worry about an IC pipe connector blowing off.
did you relocate the fuse boxs where the air pump was?
Quick Reply: My Precision 76mm turbo build
