stall/gear suggestions to use with Brute Speed/EPP cam
you could use the th400 like a powerglide with OD. treat 2nd gear as the gear youll make it down the quarter by gearing the setup that way. Since 2nd has a higher ratio. I think zombie does this but youl lstill need a big of gearing. the T56 would work well in this application, or run a smaller cam and smaller ARs on the 4.8 and gear differently
EPP cam is similar to mine. at 4k i only made 175 rwhp thats a joke thats why i said you need gearing and converter. just think about it at 4k it made 175 hows that going to do at say 2k? yes you dont race there but you still drive there
