'98 WS6 Trans Am, 8 yr old ProCharger - Not Building Boost?
I have been looking online for quite a while now. Procharger dosnt have them for sale on there website. I wish I could find a few, so I would have some price options. Could I just bypass that intercooler by just removing it and puting a straight pipe in its place? or would that screw **** up? It would still have the passanger side intercooler...
Pulling her out og the garage...
Hey guys I started this thread a while back but ended up parking the car for almost half a year. I have pulled her out for the summer and want to try to get this ProCharger thing figured out. The last thing talked about was getting it tuned. I have the cash to do this now but I just really dont think that is the main issue..
I am only getting 1 psi boost on the guage and she is definatly not pulling like she used to... Something else is wrong beside just a tune. I want to see a little more boost before I go to the tuners. I did a boost check with a device I made and there are no leaks... The ProFlo Surge Valve seems to be working fine also. The diaphram in it is brand new.. At idle the Valve opens, when I turn the car off it closes, not sure under load though... The valve is hooked up to my HVAC Vacuum line then to the FMU then straight to the valve just as the ProCharger manual states... I got the boost gauge "T"ed up to the Brake Booster line... I have removed the superchargers discharge tube and started the engine and its blowing air.. I removed the supercharger inlet and the blades look fine... Supercharger belt is brand new too and not slipping... Fuel pressure always stays around 75 psi even at WOT.. Oh and just put a new K&N on her, still nothing but 1 psi boost. I have changed the supercharger oil regularly ever 5,000 miles there never has been metal fragments on the drain magnet... Other than that sound wise, pretty smooth and normal. I have had people tell me the supercharger sounds a lil quiet but not sure if this is true. Still sounds loud to me and I have Borla Exhaust.
Im just not wanting to waste money on a tune if the head unit needs rebuilt.
Whats the newest thoughts? haha I am so frustrated on this dang car! Why no boost? Cant be just a tune right???
LS1Tech Sponsor
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
#32
What do you think?
#33
LS1Tech Sponsor
I'd bypass the bypass valve and make several runs to rule it out. I recently told a customer to do that and it ended up being the problem. You can put a piece of tubing in there in it's place. Bob
__________________
#34
Should I cap it off or put a tube in its place? I am a little confused.. If I just put in a straight tube in place of the surge valve wont it just recycle the boost through the system by passing through the supercharger then throught the tubes and back out throught where the surge valve was intially being reshot through the charger a second time? I thought the Valve had to "close" to build boost... Open to release it..
#35
Either way, I got the new diaphram in and on the ProFlo Surge Valve.
Still only 1 pound of boost at WOT....
Everything has been "boost tested" by me and is air tight. I put air in the tubes and through the intercoolers using an air compressor. No leaks, I cant find anything..
Is it time to remove the head unit and open it up?
I hate to do that but I have tried everything! Its "whines very pretty" sounds smooth as can be! I just dont get it. Very frustrating!
#36
LS1Tech Sponsor
If your system has the above surge tube, you can simply remove the bypass valve and cap off the end of the tube. This will let you know if you can rule out the bypass valve as the problem. I would only do several runs with it capped off, and try to slowly let off the throttle so the system doesn't encounter anymore compressor surge than it has too. If you don't see more than several pounds of boost you won't have to worry about compressor surge. Bob
__________________
