compression to low or no? mill heads or no?
I am getting ready to fire up my new motor & will have some dyno results in that will follow,but ,this is a street car that won't see a lot of track time ,maybe twice a month,allthough there is a lot of street racin going on here,I am concerned about the new motor that was built for me by erik koeing,not that it won't hold up but let me give u guys a run down on what I'm dealing with here;Callies crank. Callies rods,weisco -32cc pistons & an ironblock 403 ci, I am running. A novi 2k ,16 lbs of boost with juilos alky. Kit & andys fuel system,thru a chuck johnson built tranny & a pye 3400 converter,3.73 gears, patriot 64 cc heads,this brings the static compression to 8.8 to1, I talked to erik about it & he's telling me to mill the heads .030 to .35 & raise it up to 9,3 to1,the cam in the car is on a 117 +4 deg advanced in it,234/254 ,little over 605 on the lift,so do u think milling the heads would hurt the integrity of the head ,or drive it like it is & later on change the pistons out? It would be easiest to shave the heads ,I just don't wanna run into lifting heads everytime I step my foot in the gas,so maybe someone else can chime in ,let me hear what u would do?btw ,the heads have never been milled,only trued up, the bottom end is arp main caps, arp2000 rod bolts, mains & cam bearings have been coated,what I am. Thinking is the cam & the converter is really gonna help me on the low end
