question about psi and hp
Hell yes, you are forgetting about backpressure. I think I remember reading that you want to keep back pressure in the exahust lower than 2x boost. the A/R ratio has a major impact on this.
Our standard custom Spearco IC was designed to support 900-1000fwhp.
Lastly, FWIW, I'm actually using the smaller T76 housing on the Formula. It has the 4" inlet, but smaller 2 1/2" outlet. The "larger" T76 comes with a 4" inlet and a 3" outlet. Both will fit on the car with our kit, but according to John Craig of Limit Engineering, there is basically no difference in power.
I has the smaller T76 in stock, so that's what we used.
Notice Harlan said EFFICIENT setup gets 30hp/psi....I got about 23-25 hp/psi on my turbotech kit but that was with a very bad mail order tune. Once I got to the intercooler/turbo limitations, i saw the hp/psi numbers drop. Don't forget that the alky/methanol is helping Rob a lot. If he ran just gas you'd see those numbers drop to something more believable. i for one believe him.....he is right...dyno run is only 4 seconds. Rob hasn't said that his car will run 9s.....run 140mph in the quarter.....I think he is just showing what a stock motor can take for a short burst and what his kit can provide you on a forged bottom end and a good fuel system. Damn how much boost were you running to get that much of a increase? I`ve never seen my IATs go above 120 at the track, even on a 90deg day. even in stop and go traffic I don`t recall it ever going above 125* in the summer here in florida. I ran the car last weekend it was on a 70* day my temps were only 102* at the end of the run. Maybe it`s because i`m only running 8psi. I also have the front license plate area cut out so i get some flow through the intercooler.
Now sure, the thumper would have less backpressure, but you wouldn't see this manifested really in the manifold pressure; rather, the car would have less pumping losses, and could alter the cam timing to take advantage of the reduced backpressure (or to compensate for increased backpressure).
On a given engine configuration at a given boost & temp level you are getting the same amount of air in there, regarldess of the source.
Now a smaller turbo should make boost sooner/have less lag than a larger one - as to which would be more effecient, you would have to look at the map. A smaller turbo in it's effeciency range could very easily be better than a to-large turbo out of it's range (on the low side).
It seems like the same thing with a NA car that has a better header for scavenging. CFM goes up, but manifold pressure stays the same.
What am I missing here? I’ve always thought the intake and exhaust stroke were tightly related and that there was much more than pumping loss to think about with the exhaust design.
That said, I think it's still a matter of degree - I don't think it will be a large difference (more than 20-30hp max) unless we are talking extreme changes though (going from 3:1 to 1:1 backpressure) - but nevertheless, a good point, thanks!
