question about psi and hp
Old Jan 23, 2004 | 09:02 PM
parish8's Avatar
single digit dreamer
Default question about psi and hp
my question relates to the recent dyno numbers from the qmp kit. i am in no way doubting that they got 750rwhp. i am not trying to start anything, just trying to understand a few things.
from what i understand a stock 98 6sp ls1 dynos around 300rwhp
from what i understand you will double your hp for every 14.7psi of boost, that is in a perfect word where you can completely cool the air back down to ambiant and there is no restriction in the exhaust from the turbo.
with those numbers that would put a stock 98ls1 at 14.7psi around 600rwhp or less.
clearly i am missing something and like i said i am not questioning the dyno numbers, just want to know what part of the equasion i am missing.
Old Jan 23, 2004 | 11:38 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Rob has a big turbo on his car, he's running a lot of methanol to act like high octane gas (ie. like C16), and he's probably running a lot of timing.
Old Jan 24, 2004 | 12:35 AM
parish8's Avatar
i understand that. i would think that these things would get him closer to actualy doubling his hp but still not more than double. if he could cool the charge to colder than ambiant or if he was over 14.7psi then i could understand over double the hp.
Old Jan 24, 2004 | 01:04 AM
eviltwins's Avatar
In the grand scheme of things, boost means almost nothing. Can you compare the power produced by a 60-1 HiFi and T76 Q-trim at the same boost levels? Running both at 10 PSI, they're both making the same amount of boost, but the T76 is going to be making a lot more power because its moving a lot more air. A good example is look at supras, they may make 400 RWHP from 18 pounds of boost from the stock twins, but a T72 at 18 pounds of boost will make a lot more than 400 RWHP because it's pushing a lot more air. I know i'm not 100% dead-bang on with this, sombody like Harlan will probably come and correct me, but I hope you get the gist of it.
Old Jan 24, 2004 | 01:08 AM
unit213's Avatar
Administrator
The track will tell the tale with this car.
Old Jan 24, 2004 | 01:28 AM
parish8's Avatar
i am not questioning the car, the dyno, the turbo set up or anything, i love what they are doing and check the posts about their set up about 100times a day.
BUT
i think the stuff you guys are pointing out are things that would cause a lack of efficency and people to see less than the true doubling effect from 14.7psi. having the right sized turbo and good gas and most of your timing are all things that would help you get closer to a true doubleing.
i am still missing something here, from what i have read going with 14.7psi theoreticaly the best you can do is double but since you can't be 100% efficient that actualy doubeing is not posiable. that is unless there is something else thrown in to the equasion like an ice filled intercooler.
Old Jan 24, 2004 | 06:11 AM
y2khawk's Avatar
It's actually doing it more efficiently. You blow into the same motor with either turbo and get the same boost pressure (read back pressure) you flow a comparable CFM. Now, a 76 will do it but add less heat in the process. Less heat for similar CFM is where the added mass of air comes from. But, unless you're horibly out of the center island on the compressor for the 60-1, you won't see a huge gain.
Similar effect as an Ice water intercooler, denser intake charge.
a real general SWAG on a stock cammed, stock headed LS1 is about 30 RWHP per psi on a reasonibly efficient turbo setup. Seen it time and again on TTi kits, and incon kits, and QMP kits.
Old Jan 24, 2004 | 02:17 PM
slow's Avatar
also, if i am correct, as you raise boost, you increase the volumetric efficiency of the motor, therefore allowing more power to be made, than the stock *(1 +
(14.7/boost)
Ryan
Old Jan 24, 2004 | 02:28 PM
LS1Tech Co-Founder
I have a 348ci going thru a T400 u/locked and I probably make 360rwhp n/a. On blower I've made a high of 746rwhp with a lean A/F, so ~750rwhp thru a T400 would be over 800rwhp with an M6. How does that help your calculations? 400rwhp say for 17 lbs of boost equals what, 23.5 rwhp per every lb of boost so almost 30fwhp per lb of boost for me. My setup uses more power to turn the blower so it's not as effecient but we'll be able to see what all the big number setups do at the track this year. And I am probably going to step it up a bit and be a firm #2 behind Harlan on numbers. I'm sure he can go 850rwhp for sure with enuff fuel.
Old Jan 24, 2004 | 03:18 PM
qqwqeqwrqwqtq's Avatar
I think if he turned up the wick it would do 1000+rw easy.
Old Jan 24, 2004 | 03:24 PM
LS1Tech Co-Founder
That would be a pretty high bar Jim.
Old Jan 24, 2004 | 03:44 PM
It is alot of power.
So, you think a solid roller, dry sump 348 with dual T-66's, air/water coolers, and open downpipes is good for only 850rwhp?
Old Jan 24, 2004 | 03:48 PM
LS1Tech Co-Founder
Hitting 1000rwhp IMO would be interesting and he will find all the weak links of his current setup, I'm sure he would end up needing a fancier clutch and maybe to upgrade some of his fuel components.
Old Jan 24, 2004 | 09:52 PM
MYTURBOT/A's Avatar
a real general SWAG on a stock cammed, stock headed LS1 is about 30 RWHP per psi on a reasonibly efficient turbo setup. Seen it time and again on TTi kits, and incon kits, and QMP kits.[/QUOTE]
Damn i wish i made 30hp per psi of boost i only see about 12hp per psi.
I can`t understand what is so magical about his kit that it makes twice the power of a TTI kit at the same psi when there almost identical in design. Does rob know a magic switch in edit that when you flip gives you 200 extra HP because he`s the only one that can get these single turbo cars to perform with these amazing dyno numbers. He needs to start teaching other tuners his secrets so some of us can get the power numbers he`s getting. Not bashing QMP in any way Just wondering why rob is the only tuner that can get big power out of these kits?
Old Jan 24, 2004 | 09:54 PM
427's Avatar
427
Generally a TT with good cylinder heads is good for 4.5-5 hp for every CI at the flywheel.
From what I have seen the gen3 will start to have head gasket problems around 1200 at the flywheel.
I think Harlan may be using a stock crank also, not sure of its limits but I would stand back if he winds her up that high.
Should be a very exciting year coming up.... can't wait for summer!
Kurt
Old Jan 24, 2004 | 10:36 PM
Kurt
In regards to the head gasket problems around the 1200 flywheel horsepower level, was that a nitrous, supercharged, or turbo car? (or all of the above)
If the LS1 is horsepower limited due to head gasket sealing, I think a turbo car will be able to go the farthest before reaching that limit. (by far)
We should have an awesome year ahead of us.
Old Jan 24, 2004 | 10:48 PM
427's Avatar
427
I have had problems in the 975 range with cathedral port cylinder head on iron block with F1R procharger. The fuel being delivered makes me believe the engine was producing 1200 with over 200 going to turn the blower. I have made 1186hp (from memory and i'm OLD) with C5R block and heads with copper gskt and 1/2 inch studs(also with F1R).
No question the turbo engine will reach the highest numbers before pushing gaskets.
Just praying for a early summer......
Kurt
Old Jan 25, 2004 | 01:20 AM
y2khawk's Avatar
at 12 psi and only 6000 RPM it is
LOL
And yes Kurt, I'm still on a stock crank. I'm actually curious to see what it takes to break it And now that i know why i was running out of fuel, we can spin her up and twist the **** a little more.
better order some more pulleys John
Old Jan 25, 2004 | 10:12 AM
MIGHTYMOUSE's Avatar
so i guess the question is, could you do 450rwhp on a stock motor using methanol?
Old Jan 25, 2004 | 10:34 AM
cablebandit's Avatar
robs kit is different..he says his intercooler is better and I say his t-76 is the real deal...not the crippled one (for space limitation) TTi uses.
