Lt1 mainfold!!!!!!
Old Aug 22, 2010 | 04:24 AM
LTXBOI's Avatar
Default Lt1 mainfold!!!!!!
Ported stock manifold vs victor jr????? Which would you prefer and why???
Old Aug 22, 2010 | 04:30 AM
BottleFedZ346's Avatar
Victor jr. for sure there supposed to have better topend pull and you have to admit they look kickass!
Old Aug 22, 2010 | 04:41 AM
LTXBOI's Avatar
Originally Posted by bottlefedz346
victor jr. For sure there supposed to have better topend pull and you have to admit they look kickass!
lol..they do and the flow of air being forced down,instead across..... The runners....
Old Aug 22, 2010 | 05:31 AM
hitmanws6's Avatar
what are your goals? turbo or supercharger? GM high tech recently profiled a twin turbo 355 LT1 making 725 rwhp with a ported LT4 (same as LT1 internally) manifold.
Old Aug 22, 2010 | 06:41 AM
LTXBOI's Avatar
street strip setup..anything over 500rwhp...my setup 355-p1sc 8psi-75 shot-410 gears!
Old Aug 22, 2010 | 11:01 PM
crazycat's Avatar
http://www.camaroz28.com/forums/showthread.php?t=721895
Old Aug 24, 2010 | 10:38 AM
engineermike's Avatar
LTx intake!!!
For starters, 1000+ rwhp has been made using a stock casting.
Secondly, a back-to-back test was performed between a heavily modified LT4 intake versus single plane. The LT4 made more torque below 5200, they were dead even 5200-6200, then the single plane made more above 6200 (but only about 15 hp at peak). This was with a large solid-roller that liked being over 6000. On most street set-ups with hydraulic cams, you'll spend most of your time below 6200 rpm.
Mike
Old Aug 25, 2010 | 12:12 PM
4SFEDZ's Avatar
Yes like mike said, I've seen it over and over again! How high are you spinning it? Anything 6500 and under you don't need a single plane. And if you runnin a stock computer you can't go over 7k anyways! So it's all bout the rpm! But if it's worth anything I went with a heavily porter lt4, looking for sum big power with the new build!
