I beam or H beam rods??
Old Aug 24, 2010 | 09:40 PM
JAX04's Avatar
Default I beam or H beam rods??
Im half drunk and dont really feel like searching tonight, lol.
im buying my engine stuff tomorrow and need to know.
do i want to buy "I" beam or "H" beam rods??
Old Aug 24, 2010 | 10:19 PM
9sectruck's Avatar
h beams, arp 2000 or better yet L19
Old Aug 25, 2010 | 01:15 AM
TurboAv's Avatar
They even make a hybrid h/i if you want to bend your mind around that.
Old Aug 25, 2010 | 06:42 AM
JAX04's Avatar
The hell with that lmao
Old Aug 25, 2010 | 07:08 AM
Shawn @ VA Speed's Avatar
how does the l19 bolt make an h beam rod better?
Old Aug 25, 2010 | 11:26 AM
427's Avatar
427
The quality of the part means more than the base design. Both H and I designs can work well if the base material and forging process is done properly.
Kurt
Old Aug 25, 2010 | 11:29 AM
NoGo's Avatar
Kurt
I had a good conversation with a metallurgist once, and he said the same thing.
Any manufacturers that you feel have a reasonable QA for their forging process?
Old Aug 25, 2010 | 11:34 AM
3.8redbird's Avatar
Take an I and knock it over. What do you get.... H lol
Im going with I beam since thats what i have used before with good results.
Old Aug 25, 2010 | 01:23 PM
427's Avatar
427
I have visited Trenton forging to check out the process first hand, and they use clean first run material and hit every rod 4 times bringing it into shape. They forge parts for Howards, Dyers and a few smaller companies in both H and I design. I like both the Howards and the Dyers product, both have a place when properly selected. The beam of the rod needs to be strong enough for the power level and the bolt needs to match up with rpm and piston weight so it can maintain clamp load at high rpm. Most manufacturers seem to have bolts in products that will work great with the LS series of engine since the cd commonly used is short enough to keep weight reasonable.
Kurt
Old Aug 25, 2010 | 01:28 PM
night ryder's Avatar
give lunati a call and see what they recommend.
