stock cube +F1R +E85
Old Aug 27, 2010 | 10:13 PM
blue00ZZleeper's Avatar
Originally Posted by JAX04
any benefit to running a big blower on small cubes vs large cubes??
Maybe a lighter weight? Or just looking for bragging rights lol
That manifold is probably 3k+ and its beautiful lol
Old Aug 27, 2010 | 11:00 PM
venom ws7's Avatar
F1R will be hard to max out with small CI..
Old Aug 27, 2010 | 11:09 PM
Maybe 30+ psi lol....problem with that setup will be the heads/clamping force. What are your ideas on that mr big?
Old Aug 27, 2010 | 11:19 PM
venom ws7's Avatar
With his heads and his tuner that wont be a problem
Old Aug 28, 2010 | 05:20 AM
Inspector12's Avatar
TT-TECH Veteran
Its not that hard lol! I was making 28lbs with my 346 with the F1R a little past what they recomend spinning it, and a the only advantage I have seen is the TQ is a little lower and seems its a little easier to hook it on the street etc... Very nice build! GL!
Old Aug 29, 2010 | 01:16 AM
venom ws7's Avatar
28lbs is easy ??
Did you ever dyno the car with that setup? Funny how some pepole will say
you can't run more than 20lbs on LS1 without head lifting.
Old Oct 2, 2010 | 03:03 PM
Mr.Big's Avatar
1st Thanks guys for the positive comments... to answer a few questions
Originally Posted by skyhighsami
Goal HP and boost? What year Vette? How difficult is the Z06 swap and how strong is it?
Goal was 900rwhp 800rwtq 2005 C6, the only Z06 pieces are the rear fenders, they are oem pieces and fit just like factory, they allow for wider tires.
i love this build by the way!! beings that im an idiot lol, but i am curious as to the benefit of running smaller cubes vs bigger cube with the procharger??
There is no benefit, I just have had bad luck with stroker cranks, so we went with a forged stock stroke crank by my request, and no over bore, because I want as much cylinder wall thickness as possible
Originally Posted by 1INSANEGTO
Specs on intake, Price.
Its a wilson CNC billet piece, same guys that make the FAST intake, just much more "high boost" friendly. $3200
Originally Posted by Beaflag VonRathburg
That's one hell of a setup. I've been reading it in your sig for a while and wanting to see some updates. Is that a Wilson intake with a little extra work on the top? Are you running a stock crank or a forged piece?
Yes Sir wilson with custom engraving that we requested, good eye...
Fully forged bottom end, stock stroke forged crank, only reason was HKE was worried about the snout of the stock crank, with us using the direct drive and 10rib... better to be safe than sorry, however the stock crank may have been fine, we just didn't want to take chances since the direct drive puts much more tension on the belt/crank pulley/crank snout...
No issues with the heads thus far, but only dyno time and 2 passes at the track before I broke a drive line coupler. So not enough time to tell...
Old Oct 2, 2010 | 03:12 PM
Mr.Big's Avatar
Some pics, video, and results
the dyno was 94* with a horrible D.A. much left on the table...
video that a friend pt together during a Dallas vs Houston private track event we just had
only 2 passes with the tune pulled back for me to get seat time in the car, turned up heat the 3rd pass and demolished the guibo coupler, so we'll have to go back to the track after the TxMile to get some real runs in...
19in NT05R DR's first time with these tires on the car, same tire we will use for the Mile so we wanted to try them out... not so much...
hopefully they work better for the Mile...
pass 1 1.97 60' 11.01 at 134mph
pass 2 1.93 60' 10.71 at 137mph
pass 3 broke...
see link below for video
http://www.youtube.com/watch?v=ScLIjP5l15A
Old Oct 2, 2010 | 04:16 PM
Gohard's Avatar
Awesome vette, I am green with envy
Old Oct 2, 2010 | 06:43 PM
JAX04's Avatar
Yeah, that thing is absolutely Beautiful.
Old Oct 2, 2010 | 08:20 PM
helicoil's Avatar
More info on the drive set-up please.
Old Oct 4, 2010 | 10:18 AM
  #32
Mr.Big's Avatar
Thanks guys...
H.C.
On the C6 there is a serpentine belt that runs everything but the A/C. The direct drive system allows for one 10rib belt to run the headunit by itself direct from the crank pulley, and the AC belt to now spin everything else VIA a jackshaft pulley... very tidy setup, and eliminates belt slip to the headunit once and for all...
Old Oct 4, 2010 | 01:14 PM
  #33
Tiago's Avatar
baller
Old Oct 4, 2010 | 06:37 PM
  #34
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Those results are awesome for the combo. How much boost was that on?
Old Oct 4, 2010 | 08:41 PM
  #35
helicoil's Avatar
[QUOTE
H.C.
On the C6 there is a serpentine belt that runs everything but the A/C. The direct drive system allows for one 10rib belt to run the headunit by itself direct from the crank pulley, and the AC belt to now spin everything else VIA a jackshaft pulley... very tidy setup, and eliminates belt slip to the headunit once and for all...[/QUOTE]
I am not up on the Vette stuff, but is that referred to as the Cartek flip drive?
Thanks, Nice results BTW
Old Oct 4, 2010 | 09:04 PM
  #36
The Beast's Avatar
Very clean build. What are the flow numbers of your heads?
Old Oct 5, 2010 | 07:01 PM
  #37
charlie_gonzales's Avatar
Very cool build
Old Oct 5, 2010 | 07:45 PM
  #38
94 slow's Avatar
NICE! Your car sounds like a beast.
How big are the primaries on the headers? 1 7/8" or 2"?
Old Oct 6, 2010 | 06:00 PM
  #39
1baaadz28's Avatar
Direct drive, does that mean that its always making boost?
Old Oct 6, 2010 | 06:14 PM
  #40
Gordon0652's Avatar
Goddddddamn! Awesome build - like the white vette.
Keep us posted on the mile run! When will this be?
