What forged pistons/rods to use?
Over the past 6 months or so, I've been collecting parts for a front mount truck manifold setup. Originally I was going to go with a 5.3, but I recently got a good deal on a LQ4....too good to pass up. I'm weighing my options as to whether I should sell the 6.0 and use the $ to fund the 5.3 setup, or build a 370.
What pistons and rods are you guys using? I'm looking for something fairly affordable, as I'm only looking for 600rwhp or so. I'm debating running forged pistons and stock rods/crank, only upgrading to ARP hardware and new bearings. But, if the rods arent too terribly expensive, I may just upgrade them as well.
Also, what dish cc should I go with on the pistons? Stock CR seems to be 9.5:1.
Opinions? Any good vendor's selling forged pistons/rods?
Thanks
Thanks
What heads are you planning on running and what block are you thinking. Those decisions need to be made first before you can pick a piston or set a compression ratio. As far as brands go, we have been running Callies crank and rods w/ Wiseco pistons and haven't had an issue w/ either. You could put a forged piston and rod on the stock crank and easily make the power you are looking for w/ minimal boost. The pistons and rods will be the same price w/ either block. You would just have to decide what way you want to go!
Jon
Jon
Sorry Jon, I should've specified. I am looking for piston/rod suggestions for the LQ4 iron block. Will be running the stock 317 heads, LS6 cam and springs, and stock LQ4 crank.
For what you are looking at I would go Callies Compstar crank and Compstar rods. On the pistons, Wiseco has a -11cc piston in a 4.030" bore w/ stock stroke. With a factory gasket that will have you down around 9:1 static compression. You can bring it up w/ running a thinner gasket or doing a slight mill on the heads. Let me know what you think or if you have any other questions and we'll get you fixed up!
Jon
Jon
are most of these pistons a direct replacement or will an overbore be needed? im looking to throw a set of rods and pistons into my 6.0 as well but just gonna do a light hone on the cylinder and have the assembll balanced
i was thinking of just rod bolts but want to do this instead. i have a nice ball hone just gonna scuff up the bores like stated to seat the rings. not a big fan of diamond from my buick stuff so have to see what else for a stock bore is out there.
