which fans??
Old Sep 3, 2010 | 07:06 AM
camaro383's Avatar
Default which fans??
I have the conventional griffin rad that everyone uses and a single 16" spal pusher fan, and once i do street driving the ect just keeps creeping until it hits 240 and i shut it down and let the electric wp and fan run till its back down to 190ish
On the highway its stays cool, about 190
It's apparent that i need a dual pusher fan setup, but i dont wanna waste time and money on something thats not the best...so if all u front mount guys with the griffin wanna wanna help out please post up your efficient setup
Btw i am in nyc, its been hot lately, about 90's but it still shouldnt be overheating
Thanks
Old Sep 3, 2010 | 09:03 AM
jay_rich's Avatar
I use twin darale 13inch (i think) they flow 4000cf. They were 269.99 I think on summit. They only work as a puller tho.
My car runs usually 180* up to 195* depending on how hot and bc I do not have a deflector anymore since the rad has been custom mounted.
I use a griffen 27.5x19x3(2.25 core)
Jay
Old Sep 3, 2010 | 11:28 AM
camaro383's Avatar
Have any pics of ur setup, i definately cant fit a puller cause theres not enough clearance between the rad and turbo, but i seen a flexalite dual fan with shroud that moves 3000cfm's and cost $350. From jegs, i believe they are the 490 partnumber on flexalites page
Old Sep 3, 2010 | 11:46 AM
jay_rich's Avatar
I dont have any good ones of the fan setup but u can see how the rad is mounted here..
Old Sep 3, 2010 | 12:24 PM
camaro383's Avatar
Pretty cool setup, ya i mounted my intercooler about where ur radiator is...
I found some nice pusher fans, but is it better to mount them directly to the radiator or better to have a shroud, cause i would think that by putting a shrould on a pusher fan you would block alot of natural airflow
Old Sep 4, 2010 | 01:26 AM
trnsfmr99's Avatar
maradyne puller fan or pusher, that's what i run, with a front mount turbo w/ a/c. my other fan runs from a toggle switch. either fan can keep my car cool, around 190 to 210, in mid summer heat (around 100 degrees on the hot days down near new orleans). the maradyne fan with a speed control module out of jegs is like peaches and cream.
Old Sep 4, 2010 | 07:31 AM
camaro383's Avatar
Ok so i see that pretty much any of the namebrand company fans are workin for u guys, but what about running a shroud on a pusher style fan??
Old Sep 4, 2010 | 09:33 AM
camaro383's Avatar
I think im gonna get the flexalite 290 series dual 12" fans with shroud for $350. from jegs....
after some reading it seem like it gets better airflow across the entire rad rather then mounting the fns directly on the rad and only concentrating the air in one spot
Old Sep 4, 2010 | 04:44 PM
Tally TransAm's Avatar
stock radiator, not the griffin, but i use these derales. i believe they are rated at like 2000 cfm a piece
been between 90-100 degrees and the car runs around 200-205 in stop and go traffic
Old Sep 4, 2010 | 05:52 PM
camaro383's Avatar
Ya but it might be cause those are 14" each and that rad is bigger than the griffin so u have more cooling surface, i run a single 16"spal right now that is right up on the rad right now no im losing alot of surface area, and im hoping going with that dual 12" setup with the shroud so that i can utilize the whole radiator surface for heat transfer, plus im sure that single spal isnt anywhere close to 3000cfm like the dual setup is
Old Sep 4, 2010 | 09:38 PM
mine are 12"s, they should fit on the griffin with little overhang
i was always under the impression on a pusher setup you do not want a shroud as it becomes a restriction at speed
Old Sep 6, 2010 | 06:07 PM
camaro383's Avatar
Ya i can see the shroud causing a somewhat of a restriction at higher speeds, but atleast all the air from the fans is being distributed upon the entire radiator instead of concentrated area, i have a problem overheating when im not on the highway, and its good to let the fans overhang the radiator because then u loose alot of ur cfm's through those gaps
Old Sep 6, 2010 | 09:39 PM
danbap's Avatar
Tally TA do you have a part number by chance? i just changed my set up with a stock radiator and a flex-a-lite 180 covered all of rad. that would keep my car right at 180-190 no matter the out side temp. no i have no room so i need a low profile fan. and pushers. i have a spal 14" puller jammed in and it was 70 today at the temp would climb to 210.
Old Sep 11, 2010 | 07:54 AM
camaro383's Avatar
I just ordered a few goodies from jegs yesterday, along with them i ordered the jegs dual 12" pusher fan with shroud for $210. and they are good for
2600cfm's, I ordered these ones because they are only 3 5/8" thick and i could't fit the flexalite extreme pushers that flow 3000cfm's cause they were 4" plus they were $315....
so ill see how they work, ill keep you updated for whoever is interested
Old Sep 11, 2010 | 10:34 AM
danbap's Avatar
i just got my old fan to fit. flex a lite 180 moves 3300cfm had to move the radiator around but got just enough room and once again it cools fine.
