T6 rearmount with valve??
Old Sep 4, 2010 | 09:08 AM
JAX04's Avatar
Default T6 rearmount with valve??
anybody using a t6 flange turbo with a spool valve out back???
I thought that longerangr4u used a t6 flanged turbo??
Old Sep 4, 2010 | 09:39 AM
1CAMWNDR's Avatar
That is a great idea!!!
Old Sep 4, 2010 | 12:20 PM
Gonoma's Avatar
thats what ill be doing
Old Sep 5, 2010 | 08:11 AM
Sluggish's Avatar
Zombie
Old Sep 5, 2010 | 09:18 AM
JAX04's Avatar
Thought he was a 1.25 t4?????
Old Sep 5, 2010 | 10:41 AM
Zombie's Avatar
correct. if i did it over id go T6 but i'm tired of spending money changing setups, especially when what i have now works ridiculously well.
I was the first to try a valve (one of the first with a rear mount too, since 2004) and took a gamble that paid off huge.
Old Sep 5, 2010 | 10:51 AM
JAX04's Avatar
trust me, lol. i appreciate everything you post up, all your findings, etc.
i dont really care if im bashed by people, hell, even my local guys give me ****, i dont care. its about making a choice and staying the course.
im already rearmount, and im going to make it the best possible. Sooner then intended.
care to explain why you would go t6 if you did it over again?? i know they are phsyically larger then the t4, and probably flow alot better on the top end. but im concerned about the ability to spool off the line, even on a brake. not sure if the difference is that big, or if its negligible or not. any thoughts\?
Old Sep 5, 2010 | 09:06 PM
Zombie's Avatar
I'm on E85.
Old Sep 5, 2010 | 09:10 PM
JAX04's Avatar
me too
Old Sep 5, 2010 | 09:32 PM
jdmotox333's Avatar
why are you running e85 what are the benefits of it when it burns 2 to 1 of 93 almost so i heard
Old Sep 6, 2010 | 01:44 AM
Zombie's Avatar
2.29/gal here and can make as much power or more than C16.
Old Sep 6, 2010 | 08:27 AM
JAX04's Avatar
1.99 here
Old Sep 6, 2010 | 09:32 AM
jdmotox333's Avatar
but if your pay 2 dallors a gallon and burn 2 to one you burn 4 dallors to make the same power??? but idk where i live the closest e85 is 15 mins or 20 mins and it be more of a problem having to drive there to get fuel before i went somewhere
Old Sep 6, 2010 | 09:47 AM
Gonoma's Avatar
it doesn't use 2:1 its closer to 30% more than regular gas. Just research e85. It has a higher octane level than 93 and more like 110 or c16 performance wise but a whole lot cheaper than $8.00+ a gal
Old Sep 6, 2010 | 09:50 AM
jdmotox333's Avatar
oh i was always told it burns somethin close of 2 to 1 but okay that sounds alot more resonable but yeah cam2 here is 6 dallors so i could see going to that instead if i need to run such a high octane
