Supercharger compressor clutch
Old Sep 4, 2010 | 10:34 AM
vtirocz's Avatar
Default Supercharger compressor clutch
Anyone have a compressor clutch on their supercharger? Similar to fan clutch or AC compressor clutch, etc. This would make it possible to engage it based on % throttle, engine speed, etc.
A bypass valve would also accomplish what I'm looking for.
Just curious if anyone has looked into this and what they found.
Old Sep 4, 2010 | 11:38 AM
camarols1's Avatar
An A/C clutch will fail quickly as they were not meant to handle that kind of load.
It sounds like a fun idea, but it will fail in practice.
I would save the time and energy and go with a proven conventional supercharged or turbo setup.
Old Sep 4, 2010 | 01:31 PM
Pocket's Avatar
Using a bypass valve to recirculate the pressure does the same with very simple parts
At low load all the boost is vented back to the SC inlet so the blower freewheels. This lowers the drive cost to about that of an idler pulley
Old Sep 4, 2010 | 03:20 PM
old motorhead's Avatar
A TVS essentially does all that for you. No load from the s/c under vacuum conditions and boost instantly available once you mash the go pedal. My TVS2300 will go form cruise vacuum to full boost in an instant at anything over 2500rpm. Hell, it will go from cruise to full boost under 2500rpm, but it's just a little tough on the motor.
Old Sep 4, 2010 | 04:21 PM
vtirocz's Avatar
With a car A/C clutch, you're probably right. But what about fan and a/c clutches off medium duty diesels... some of those look like they might work for a ~6psi system.
Thanks for the input. How much did that setup cost, if you don't mind my asking?
Old Sep 4, 2010 | 09:52 PM
DAVESS02's Avatar
If I remember correctly, mercedes benz had a clutch type SC in the 90's or at least one experimental type. I think it had reliability issues or they built a better mouse trap. Personally, looking like Mad Max would be bad azz IMO! An electromagnet operating on a higher voltage like 60 vdc might be able to handle the load but that might cause interference with other electronic components.
Old Sep 4, 2010 | 11:06 PM
TT350's Avatar
I've seen ac compressors lock up on the highway and burn the belt off the motor.
The clutch has the ***** to burn up a 6 rib belt it will carry the blower.
Now engaging the clutch and taking the blower from a stand still mite give the gear box
in the blower a hard time.
If you engage the clutch with the motor not running and started the motor
that would be ok but if your looking to hit the blower "mad max" style
on the run that's a different story.
Old Sep 5, 2010 | 09:18 AM
Pocket's Avatar
It should constantly freewheel when not under load just from the air passing through it. Itll never be stopped unless theres a mechanical issue or the engine is also stopped
Old Sep 5, 2010 | 06:27 PM
stoopid john's Avatar
We have a toyota previa at the shop that has a factory supercharger with a clutch on it. If you drive it right, you hear it click on, then feel the boost, weird.
Old Sep 5, 2010 | 09:35 PM
Professor_speed's Avatar
look into rotex superchargers they use clutches
Old Sep 5, 2010 | 10:04 PM
pdasterly's Avatar
http://www.atiracing.com/superpulley/index.htm
Old Sep 5, 2010 | 11:10 PM
LS2Ttype's Avatar
i seen something about a year ago, I think ATI was working on it , the crank damper/blower pully had a 2 or 3 to one step up ratio, where it would multiply blower rpm vs engine rpm so lets say at normal 3,000 engine rpm the blower is spinning at 20,000 rpm, you adjust the pully to 2 to one , now at 3,000 engine rpm the blower is at full rpm 40,000 and pretty much full boost, so say your engines power range is 6,000 rpm , the pully system will go back to normal 1 to 1 ratio, and still increase boost till max rpm or blower speed lets say 60,000 rpm,, might be a little hard to understand but i think u will get it .
Old Sep 5, 2010 | 11:11 PM
LS2Ttype's Avatar
Now if i was to use something like this on my car, making 740 RWHP street car, it would be undrivable , and i would be blowing the tires off the wheels
Old Feb 7, 2020 | 09:21 PM
Manuel Lavoie's Avatar
Check out Saleen S281 supercharger pulley.... It's made like this....
Old Feb 9, 2020 | 07:59 AM
cdk4219's Avatar
Holy 8 years! All Mercedes kompressor cars have electric clutches on the Eaton superchargers They work well
Old Feb 9, 2020 | 10:00 AM
truckdoug's Avatar
and mad max's car had that **** in the 80's
