L92 boost results
Old Sep 28, 2010 | 11:39 AM
  #41
bottlefed370's Avatar
So did u get ur injectors in? I would like to see how it runs for u now.
Old Sep 28, 2010 | 12:00 PM
  #42
Chevy406's Avatar
Some very helpful information in this thread for those of us currently in a turbo build. I too have the Magnafuel 4303 pump, but I plan on running 93 pumpgas so it sounds like the pump will be adequate for me. I can see that I need to go ahead and upgrade my 60# injectors...
Thanks for taking to time to share your build and your success. It helps motivate those of us who still have a ways to go on our projects.
Old Sep 28, 2010 | 04:43 PM
  #43
cjg454ss's Avatar
yeah i hope this helps. here is the information ive gathered.
4303 magnafuel pump pairs great with 100lb injectors(ford 80lbers) on E85. when the pump maxes out the injectors will also be around 90%. this is boost referenced. My next step is to no reference the regulator. Plus now i need a bigger pump or maybe a second 4301. Either way the 4303 was a big disappointment. Another similar setup on a different car had the same issue at the same power level.
Old Dec 16, 2010 | 08:35 AM
  #44
lt1773's Avatar
good result
Old Dec 16, 2010 | 01:16 PM
  #45
fouroff's Avatar
Default Nice set up. Can you tell me some more?
Originally Posted by camaro383
Interested to know what fuel system specs are, tank,pump,lines etc,???
Im running e85 as well with dual walbros and stock lines no return up front, and 96lb. Injectors... only pushed up to 11lbs and 15degs timing so far so good, but im sure im prob only good to about 750rwhp with my fuel setup on e85
Thanks
Sounds like you have a nice set up on your fuel system. I'm trying to set up a budget system similar to yours. I'd like to try to utilize dual walbros and my stock lines to feed a stock LS3 intake/rails(ie - avoid the big $$ pump/SS braided lines/aftermarket fuel rails/etc.). It sound like you've successfully done what I'd like to do. Can you tell me what brand injectors you're running? Are you happy with them? Do you know what duty cycle they're at for the 11 lbs and 15 degs you ran? What RWHP were you at for that set up? Thanks!
Old Dec 17, 2010 | 06:50 AM
  #46
tording99Z28's Avatar
So what is the general concensus on this? Are the L92 heads sufficient enough to make 900-1000 HP without pushing water on a non-filled block? I would love to run L92's on my upcoming build but worried about the thin deck on them and having head gasket issues.
Old Dec 18, 2010 | 12:29 AM
  #47
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
x2....
Old Dec 18, 2010 | 03:06 PM
  #48
cjg454ss's Avatar
id say 18psi with the block oringed with some mls.....yes it will work. remember if you had a 6 speed you would make 1000rwhp easy. th400 id say 850-900rwhp would be possible without any issues.
Old Dec 18, 2010 | 03:15 PM
  #49
lt1773's Avatar
so without o-ring the block how much can cope before the heads lift up??
Old Dec 18, 2010 | 04:56 PM
  #50
lunati397's Avatar
Ok im not new but when you are stating "filling" or Half "filled" you are refering to cementing the block or am I way off and what has to be accomplished to Oring your setup be it heads or block or both
Old Dec 18, 2010 | 06:44 PM
  #51
396375's Avatar
I'd like to see a comparison with a similar motor with thick deck aftermarket heads and no O rings or filled block.Great info and amazing #s.I'm surprized the half filled block wasn't more of a heating problem.I figured it was a track only deal.
Old Dec 18, 2010 | 08:13 PM
  #52
cjg454ss's Avatar
i have a large oil cooler but my car runs at 180 all day. half filled. i now have some lsx thick deck l92s and havent had any water issues.
Old Dec 18, 2010 | 08:41 PM
  #53
BLOWNALKY01's Avatar
Pretty decent numbers!
Old Dec 19, 2010 | 01:55 AM
  #54
lt1773's Avatar
nice nice
