My single frontmount build thread
Old Jan 18, 2011 | 08:17 AM
  #61
CarsandWomen's Avatar
Originally Posted by 98Camarod
^^Nice work! On a side note, I have the same salt shaker.
matching pepper shaker too? hows your car coming along?
Thanks for the compliments fellas!
CarsandWomen, if im busy its probly because of one of the two, my car got ignored most of this weekend but i did clean out the garage and get started on the fuel pumps
Old Jan 18, 2011 | 10:02 AM
  #62
98Camarod's Avatar
You know it!
I've got the motor and trans out. I painted the motor and oil pan. I'm slowly working on it. I've got a wife and kid and soon I'll be goin out to sea.
Old Jan 18, 2011 | 02:42 PM
  #63
krissoto's Avatar
nice build, how long u think it will take before its back up and running?
Old Jan 18, 2011 | 03:27 PM
  #64
kdavis's Avatar
Can't wait to see how u route the 4in dp and keep ac.
Old Jan 20, 2011 | 03:27 AM
  #65
as long as it takes me to come up with the cash to build the 4l80e, im pretty well taking my time with everything else. Biggest thing right now is doing all the things i can for the cheapest, but its going at a decent pace for now.
me too it comes off the turbo as a 3.5 inch, where it steps up im not sure yet. i think ill try and snake it over the K member on the driver side but well see. Many things are still up in the air that will dictate it
Old Feb 13, 2011 | 04:06 AM
  #66
Im seriously regretting these Spohn solid motor mounts, a huge PITA to put in even when you can literally get right next to em, the motor is a solid 1.25" higher (hits the alternator on the hood) and it appears that im not crazy and the PASSENGER side doesnt fit because the bolt holes dont line up. I also dont think my LGM STB will fit, it will hit the intake. Before I bought these I measured to see if I had an inch to give for em and I did, barely, but I had it.
Now I dont, so IF i can get the bolt holes to line up ill have to modify the alt bracket to drop is as much as possible, if the bolt holes dont line up ill use the spohns for parts and make new ones from scratch. I paid good money and had high expectation for those
fuel fitting for the pumps is at the machine shop getting liposuction, still trying to source the two brackets that bolt to the core support so i can start making the final draft of the upper support bracket, works picking up so the money should start running a little thicker thank god, it appears my BMR 4l80e trans crossmember might not fit right but im getting some pictures to them to try and figure it out. Today was a huge bummer all around.
Old Feb 13, 2011 | 11:28 AM
  #67
Reject's Avatar
ok loving the progress so far and it gave me some new ideas on how to do my setup. i like how you have the IC and radiator mounted up, i may do something like that but with aluminum tubing.
Old Feb 13, 2011 | 09:50 PM
  #68
slow67's Avatar
Gingervitis Addict
Get the motivative solid motor mounts, not supposed to raise the motor at all.
Old Feb 13, 2011 | 10:10 PM
  #69
^^^thats what im looking at, Ill prob make some pedestals out of scratch to clear more room for the turbo piping
Old Feb 14, 2011 | 01:48 AM
  #70
kmracer's Avatar
^ if you're gonna go that far, might as well just modify the spohn ones...
Old Feb 14, 2011 | 02:34 AM
  #71
probably will, the powder coat on the Spohns is destroyed now anyway. getting the whole thing to sit square and high enough will be a tough task but its better than stock mounts lol
Old Feb 14, 2011 | 03:36 AM
  #72
kmracer's Avatar
i agree. i decided to build my own engine mounts and transmission trans x member in my car, it took me about 2 weeks of working 3-4 hours a day. granted, its a conversion and im ****, but **** what a pain in the ***.
Old Feb 14, 2011 | 05:27 AM
  #73
The part I dont like about it is there isnt anything I can do right now, Im waiting on something in every direction.
I need to somehow roll my tranny over and measure the pan so i can make a cradle for it to sit safely on my floor jack. g2g thanks for the revelation fellas
Old Feb 17, 2011 | 02:40 PM
  #74
MillsMotorvation's Avatar
Get me one of those Y's for the fuel made, and send it to me!!
Old Feb 17, 2011 | 02:51 PM
  #75
1badWS6's Avatar
I need one too lol... how much did it run ya?
Old Feb 18, 2011 | 07:01 AM
  #76
he gave it to me i did mention I might order more though. currently it doesnt fit, with the barbs on there isnt enough room between the tops of the pumps and the bottom barbs. top is the same way so im making a few modifications to it to shorten it all up some, once its all done and it fits then ill see about having a few extras made and let yall know.
Old Feb 18, 2011 | 07:22 AM
  #77
1badWS6's Avatar
Are you just going to try and shorten the barbs, or are you gonna shorten the entire piece?
Old Feb 18, 2011 | 07:29 AM
  #78
both, im having roughly 3/8" cut off the single out and having the threads tapped deeper into the block to allow all 3 fittings to screw in farther. Im trimming the end barb off each barb, and i took out the 3/8 to 1/4 bushing and 1/4 npt 5/16 barb ( the single out fittings) and ordered a 5/16 barb x 3/8 npt. the block is at the machine shop with all three fittings right now
Old Feb 18, 2011 | 08:48 AM
  #79
1badWS6's Avatar
Cool! Throw up some pictures when you get it back!
Old Feb 18, 2011 | 03:39 PM
  #80
going to pick it up in just a few minutes.
