Turbo cams: VA Speed vs Speed Inc vs Brute Speed vs LS9?
Old 09-16-2010, 08:55 AM
Shawn @ VA Speed's Avatar
Originally Posted by engineermike
Sure, but people have been touting reverse-splits for LTx and SBC's for years, and they don't work that well on those. I don't see where the physics of the LSx is that much different (v-8, 2v, similar cid, similar pressure ratios).
I've never seen a back-to-back dyno test where a reverse-split gained power over a conventional split. I have seen the opposite.
really?the fastest sbc turbo car on the planet has a reverse split.Why don't you tell him it don't work.
Old 09-16-2010, 10:07 AM
Kx69's Avatar
I think that the custom turbo cams are some what of a joke.
I have spoke to 3 cam companies and 4 of the big LS shops giving them the exact same setup specs/driving conditions/power (some of them I filled out there paperwork) and received 7 different cam specs (some not even close to one another). 2 of which were reverse splits, and one recommended the factory LS9 cam for the same combo. I even paid one of the “best” cam manufactures for there recommendation (which was a reverse split). All have excellent reputations, make fast cars and some killer power on there cams or engines that they build.
I also find it comical how some of them give specs to the tenth of a deg of duration (ex. 246.2). Yet the other expert cams don’t and are maybe 4-5 deg difference. But the first company nails it down to the tenth.
That must be so you can tell your friends that you have a very extra super spec top secret custom turbo cam.
Old 09-16-2010, 10:12 AM
Restricted User
98Z28CobraKiller's Avatar
The thing is that the "pros" usually dont pick the correct cam on the first try even for themselves. The guys that are squeezing the most power out and are racing competitively with big budgets for R&D will order up three or 4 cams before they find the best one. There are just too many variables and no magic formula.
Another thing to note is that if you took the first three cams that the OP posted and did a head to head comparison between them with the exact same combo on the exact same boost, they would all be within 20 rwhp of each other. So if you did end up with the slowest one, you could just turn up the boost .25 psi and make up the difference.
Old 09-16-2010, 10:37 AM
TurboAv's Avatar
Truth.
Old 09-16-2010, 10:39 AM
qqwqeqwrqwqtq's Avatar
Saying a certain combination needs a reverse split is like saying it needs a certain LSA. They both mean almost nothing.
If you want to debate cams talk about valve events.
You will max out a single 76GTS before a TU1 cam is leaving anything on the table.
Old 09-16-2010, 11:02 AM
engineermike's Avatar
Show me his dyno sheets proving he gained power over a comparable conventional split.
Old 09-16-2010, 11:03 AM
...But when you are running a small exhaust housing for the cubes, a reverse split is beneficial IMO.
I don't know what you consider a small exhaust housing for the cubes, but I was running a 76GTS on 388 cid and lost power when going from a conventional split to a single pattern.
Old 09-16-2010, 11:07 AM
7 Second Club
Phil99vette's Avatar
More peak power doesn't mean its going to be faster...move average power does....
Old 09-16-2010, 12:30 PM
he doesn't race dynos just racetracks and he's been fastest with the reverse split.
Old 09-16-2010, 12:39 PM
XtremeDime's Avatar
Shawn, while youre posting in here. Whats the LSA on your VTC2 cam?? Also whats the RPM range this cam is good for?
Old 09-16-2010, 02:12 PM
more than 115-it will make power from 3000rpm to over 7000 if you have the turbo and valvetrain to get it there.We have found the turbo dictates the power range more than the cam does
Old 09-16-2010, 02:25 PM
  #32
XtremeDime's Avatar
Would you think it would pair well with my setup?
Old 09-16-2010, 02:29 PM
  #33
ATVracr's Avatar
lmfao !!!
Old 09-16-2010, 02:40 PM
  #34
So how fast has he been?
Old 09-16-2010, 03:17 PM
  #35
i believe the fastest is a 5.94 at 240+ 427 sbc with a single 105
Old 09-16-2010, 03:32 PM
  #36
Call me crazy, but it seems like a couple of guys running 9's at 140 - 150 mph, who gained performance when switching away from a reverse-split, experience would be more applicable to a 346/T76 than a 240 mph 105mm combo.
Old 09-16-2010, 03:43 PM
  #37
yelo04goat's Avatar
interested in this also wondering on street manners and recommended stall
sent pm few weeks ago with no answer your probably super busy and i am deployed so there is no rush,
thanks for all the great info guys!
Old 09-16-2010, 04:23 PM
  #38
MUSTANGBRKR02's Avatar
I have the TU1 in my 370 and the car runs great. After I swap in this TH400 i should be getting it to the track.
Old 09-16-2010, 04:25 PM
  #39
427
427's Avatar
The reverse split stuff has always worked well for me also in the LS series of engine. I have used them in high power stuff, but also run one in my 900hp Silverado. Not sure they will produce the highest dyno numbers, but in car/truck testing has shown better et in quarter mile racing.Longer ex duration would help the hp numbers with a faster ramp of the rpm like on a chassis dyno, but should show tq loss at lower rpm and struggle a bit when the gear change happens and the engine needs to accelerate after getting the wind knocked out of it.
OP: Virginia Speed/Speed inc will not steer you wrong on your project although they may have different opinions. Generalization is a tough road, but in your case I would run the reverse split as I believe it will help you overall with drivability coupled with smaller turbo/combo.
Kurt
Old 09-16-2010, 05:05 PM
  #40
Hi Kurt
What is it you like about a reverse split cam on a turbo application? What are you trying to achieve with the valve events that the cam ends up being that way?
Another thing is, I wish we were talking more actual numbers.
I mean, if my cam is 225/225 @.050 and someone goes with a 225/223 @.050 because it's a reverse split I find that amusing as the valve events would be very similar.
Quick Reply: Turbo cams: VA Speed vs Speed Inc vs Brute Speed vs LS9?
