C6 twin 76 build
Old Oct 3, 2010 | 09:47 AM
Josh@PremierAutosports's Avatar
950whp can be done with alot less turbo so absolutly no problem at all. What size turbos is your TTi kit running and how much power are you making now?
Old Oct 3, 2010 | 10:35 AM
396375's Avatar
I'm embarrassed to say I'm not sure.Here is a pic.I think they are T28s.
Thanks
Old Oct 3, 2010 | 11:10 AM
Measure from bolt hole to bolt hole on the exhaust housing flange. Let me know what the 2 measurements are.
Old Oct 4, 2010 | 06:46 AM
chuntington101's Avatar
Josh,
Have you got any pics of the manifolds used? or are you using stockers with a joining section?
Regards,
Chris.
Old Oct 4, 2010 | 09:13 AM
onfire's Avatar
Coal Mining Director
Thanks
Looks like a T3/T4Hybrid. If it is, you should be able to get something from Turbonetics that would equal a GT3582R and make 1000rwhp.
Old Oct 4, 2010 | 12:30 PM
adam205348's Avatar
nice looking setup, kinda of a mixture of the aps/tti and the hpperformance turbo setups. Can you get any more pics of the cold side how it was ran?
Old Oct 5, 2010 | 05:10 PM
black98ws6ta's Avatar
After looking at another c6 it looks like there was a few peices of sheet metal removed to fit the turbo's there. Is it open under those peice of sheet metal?
Old Oct 6, 2010 | 10:56 AM
Dustin@PremierAutosports's Avatar
Yes sir. Wide open. In the process of building tubular braces to replace the removed metal.
Old Oct 6, 2010 | 11:07 AM
Ws6kid.'s Avatar
that looks sexy!
Ws6kid.'s Avatar
how much boost are u planning on getting?
Old Oct 7, 2010 | 11:25 PM
396375's Avatar
Sorry I took so long.Replacing a head gassket right now.My turbos are the
58MM.Not the upgraded 62s.Do you still need those measurements?671RWHP @ 14#s.
Old Oct 8, 2010 | 02:43 AM
  #32
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Why are you guys using that dump tube muffler setup instead of tying it back into the DP?
Old Oct 18, 2010 | 06:01 PM
  #33
I'm going with the easiest to modify later. The customer wants to drive it turbo'd with the 6 speed for a month or so. Then its going back under the knife. Its getting a 4L80 up front, a solid 9" with a torque arm, a cage and 6 bolt heads.
This entire exhaust setup is to be short lived.
Old Oct 18, 2010 | 06:13 PM
  #34
V-seriesTech's Avatar
Very very cool setup. If I was doing a low mount like that,..i'd cut the rails too. More then enough MEAT on these cars for that. Tight work dude,..it's gonna be a handful.
Old Oct 21, 2010 | 09:54 AM
  #35
I have been slacking on the photos.
Old Oct 21, 2010 | 10:21 AM
  #36
is the air filter piping or intercooler piping going to cut down on turning radius any?
Old Oct 21, 2010 | 10:23 AM
  #37
Phil99vette's Avatar
7 Second Club
Pretty sick build
Old Oct 21, 2010 | 11:29 AM
  #38
100% not at all, we have checked and tested a number of times. I have more pics on the camera to upload soon.
Old Oct 22, 2010 | 09:44 AM
  #39
Here is the skid plate protecting the turbo incase you run over something just wrong. The turbo isn't the lowest point on the car but this is just incase. This gets caught up to the way the car sits right now this morning.
Old Oct 22, 2010 | 09:55 AM
  #40
cracker's Avatar
Great job guys!
That is pimp for sure!
