My PT76 Front Mount Build Thread.....
Old Sep 23, 2010 | 01:08 AM
BottleFedZ346's Avatar
Arrow My PT76 Front Mount Build Thread.....
Alright i have been working on my car for a while now and im still not done although im shooting for her to run again near the end of this year.....Keep in mind im 22 and doing this build in my father's garage with limited tools/budget, this is also my VERY 1st build of anything so i have ALOT to learn if you guys feel i need to change anything or did something wrong please feel free to tell me as im still a "newb"........
Alright here's what the build consists of:
Aluminum 5.3 (stock bottom)
Z06 cam
317's with crane springs
GM MLS
Spohn solids
Victor Jr.
Etc.
Turbo setup consists of:
Truck manifolds
Precision 76mm
2.5 mild steel crossover
3inch dp
34x13x4 intercooler
Etc.
Time for some pics!
Old motor out!
New motor and Spohn solids in!
Mounting the FMIC......
Mocked up heads......
I went to mock up the Victor Jr. setup and found out quik i had to do some cutting!
After i got that done i decided to notch the k-member and throw on the manifolds......
Next day i got curious and decided to see what it all would look like!
The other day i got crazy and deleted the cruise/abs and started to cut the radiator support i still need to lower the base which im hoping to have that done this weekend along with swapping in the 5.3 cam!
I also figured i'd paint the valve covers as well while there off!
Thats about it for now until i can scrape up some cash and buy new parts i will keep this thread updated as much as i can!
Old Sep 23, 2010 | 04:24 AM
Nitroused383's Avatar
Looking good so far, do you have any pics or details on how much you had to notch the k-member?
Old Sep 23, 2010 | 04:40 AM
MUSTANGBRKR02's Avatar
Its a good little piece you have to cut out on the k member.
Old Sep 23, 2010 | 10:14 AM
Not at the moment but i could take some if you like as stated its a good little chunk!
Old Sep 23, 2010 | 10:52 AM
transammiller's Avatar
Restricted User
i love that paint you have on the valve covers. you should do your intake and other stuff on the motor with it. that is pretty cool. hell even the cold piping and compressor would look cool done with that.
Old Sep 23, 2010 | 11:53 AM
JAX04's Avatar
what paint is that??
Old Sep 23, 2010 | 01:10 PM
The paint is VHT black crinkle paint should be at your local Autozone.....
Old Sep 23, 2010 | 02:51 PM
GM PHASST's Avatar
Is the exhaust gonna be 3 inches all the way back and are you using the stock fuel system?
Old Sep 23, 2010 | 03:08 PM
Restricted User
I believe he is doing a 3" exit in front of the wheel.
Old Sep 23, 2010 | 03:30 PM
Just as Miller said it will be a 3inch drivers side exit thru the bumper.....
As for the fuel system i will be running twin walboros with stock size feed/return and 60lb injectors.....
Old Sep 23, 2010 | 03:42 PM
Restricted User
just use the EVAP line as the return and use the stock feed. just get a nice Fuel pressure regulator with a boost referece port. I am running two -8 lines for my new twin setup and a -8 for a return.
Old Sep 23, 2010 | 04:26 PM
Yes thats also on my "parts list" along with a 235356546 other things lol.....
Old Sep 23, 2010 | 05:50 PM
TX RED's Avatar
looks real good.....I should be starting on mine very soon. still looking for a z06 cam and some small stuff
Old Sep 24, 2010 | 12:03 AM
Thanks man!!!!
Old Sep 29, 2010 | 02:43 AM
Hmmmm ok guys im a little confused i'd like to know what headgaskets to go with.....
I have decided to just go ahead and run GM MLS but im not sure what bore/thickness will be best if anybody can provide part #'s or what not ill go ahead and order them!
Old Sep 29, 2010 | 07:09 AM
Best deal right here $28 / pair
http://sdparts.com/details/gm-perfor...parts/12498544
Old Sep 29, 2010 | 03:08 PM
Ok heres the headgaskets i came up with after running the part # (# 33 on the list you posted) and this is what came up......
http://www.summitracing.com/parts/NAL-12589227/
The bore is diff. as well as the thickness either one will work correct?
Old Sep 29, 2010 | 04:17 PM
5.3 doesn't have a 4" bore, you want to run the ones I posted a link to from Scoggin Dickey.
Old Sep 29, 2010 | 05:09 PM
slow67's Avatar
Gingervitis Addict
Wiseco has some 5.3L forged pistons on the shelf.
Old Sep 29, 2010 | 05:24 PM
Restricted User
whats the point of a 5.3 if you are gonna use forged internals? thats why i love them. Rock em' and pop em'!
