Big boys turbo suggestions
Old Sep 28, 2010 | 11:04 PM
lordrazo's Avatar
Default Big boys turbo suggestions
PLEASE SUGGEST THE RIGHT TURBO AND WHY THANKS GUYS NEED THE SUGGESTIONS I WAS THINKING A GT88 OR PT88 OR BIGGER?
I have a lt1 396 stroker splayed lt1
afr 210cc comp port #1101
victor efi port matched to heads 1206 gasket
HI FLOW elbow with 90mm tb
je custom -31cc pistons
lunati 5.85 forged rods and calies forged crank
pro turbo gen 2 kit just a dump pipe no exhaust purchased from www.forcedinductions.com
160 lb. Injectors running e85 fuel
FAST xfi ecu AND WIDEBAND
solid roller cam 244/247 .664/.664 115 with a
1.6rr
** TH400 **
12bolt 3.42 gears
28" tire
race weight with driver 3500 lbs
I want max effort 20-25 lbs boost high hp trailered drag car little
street driving
im probably going to redline @7000 rpm
im looking to make around 850 but would like to hit that 1000hp on the dyno
if you get what im saying I hope you suggest something good (right now I
have an art carr 3800 with billet cover)
Old Sep 29, 2010 | 12:28 AM
black98ws6ta's Avatar
GT88 should be fine. Anything t4 is too small.
Old Sep 29, 2010 | 01:58 AM
yelo04goat's Avatar
114mm!!!!!
Old Sep 29, 2010 | 05:10 PM
lordrazo's Avatar
anyone with similar combo and dyno sheets?
Old Sep 29, 2010 | 05:44 PM
Jordan_NationalSpeed's Avatar
GT47118R (118mm exducer, 88mm inducer) with a 1.39 a/r turbine housing, in my opinion.
Easy 850whp, and definitely capable of 1,000whp.
Old Sep 29, 2010 | 11:19 PM
lordrazo's Avatar
any other suggestions curious why i would go with a 114mm over a 91 mm over a 88mm?
Old Sep 30, 2010 | 03:04 AM
kmracer's Avatar
i'd go with an 88 or 91, i'd talk to FI though.
Old Sep 30, 2010 | 07:59 AM
lordrazo's Avatar
ya I was thinking the same
Old Sep 30, 2010 | 08:07 AM
Phil99vette's Avatar
7 Second Club
Precision 91 to 94mm.
Old Sep 30, 2010 | 09:32 AM
slow67's Avatar
Gingervitis Addict
Heres another LT1 car.
https://ls1tech.com/forums/forced-in...4x-dyno-s.html
Old Oct 1, 2010 | 06:01 AM
lordrazo's Avatar
wow thanks slow67 see i have a proturbo gen2 kit coated i can modify some but not sure how efficient the kit is its a t4 but i can use a merge plate to a t6 or weld one on iif needed anyone familiar with the kit shame they are out of buisness
Old Oct 2, 2010 | 01:51 AM
lordrazo's Avatar
wow thanks slow67 see i have a proturbo gen2 kit coated i can modify some but not sure how efficient the kit is its a t4 but i can use a merge plate to a t6 or weld one on iif needed anyone familiar with the kit shame they are out of business
