Now im scared to put motor in
Here the thing, i got a 6.0 from a friend that came from a 2004 work van, with 43k on the clock. LKQ of ohio.
well, that said, hes a curious cat like me, and pulled 2 main caps and two rod ends to get a look at the bearings, well, i went ahead and did a bit of research on here looking for the correct sequence and amounts to torque the caps and ends back.
then, i read alot of people saying if you take them ends off, or the main caps off, you MUST replace the bearings in the motor. well ****, ive spent the night torquing the bolts and studs back to spec, and rod bolts to spec per ARP.
Now, im completley second guessing my choice of doing this.
I do this kind of **** all the time. what to do.
