Boost solinoid.
Old Oct 2, 2010 | 09:17 AM
396375's Avatar
Default Boost solinoid.
I'm looking to run a simple boost solinoid to give me 10#s on the line and then hit 16#s once on the move.Has anyone done this recently and how did it work?Which solinoid did you use?
Thanks
Old Oct 2, 2010 | 08:25 PM
skinnies's Avatar
I do it, use a manual boost controller inline with a GM boost solenoid(from typhoon), then when I hit the button on my steering wheel it goes from low boost to high boost.
Old Oct 2, 2010 | 08:34 PM
Phil99vette's Avatar
7 Second Club
I've got a MBC setup out in the shop brand new if your interested. $25 to your door.
Old Oct 3, 2010 | 01:49 AM
396375's Avatar
Thanks.I already have an RJC boost control valve.I'm looking for a electronic solinoid that will go from low to high boost with a switch.
Old Oct 3, 2010 | 01:52 AM
396375's Avatar
What is your low and high boost settings and are they adjustable?How did you setup up your hoses?Dosen't the Typhoon solinoid need a signal from an ECM to work or is it just 12 volts?
Thanks
Old Oct 3, 2010 | 05:20 AM
skinnies's Avatar
Just needs 12 volts, the low setting is whatever spring you have on it and the high setting is whatever you set the manual boost controller at.
Lines are simple, put a Y before the noid and mbc on one side of the Y and just straight hose on the other. The noid is 3 port, very simple.
skinnies's Avatar
Old Oct 3, 2010 | 09:53 AM
396375's Avatar
Thanks guys.
Old Oct 3, 2010 | 10:13 AM
7 Second Club
If u need a valve call seb at nlr the guys that make the ams-1000...u might need 2, one to put the pressre on and one to release.
Old Oct 5, 2010 | 08:38 PM
bad6as's Avatar
get a ams-500
Old Oct 6, 2010 | 12:59 AM
396375's Avatar
Originally Posted by bad6as
get a ams-500
I'll be getting a 1000 this winter.I just need something simple to get me off the line till the end of the season.
Thanks
