I suppose its time to make a build thread...truck manifolds!
#81
I found a heater hose adapter that has a spot where I could run the steam vent tube to. But Ill deal with it when the time comes.
#85
Alright guys, so Ive decided to go in a slightly different direction. An old hi-flo kit came up for sale and I jumped on it. I figured the cost of buying the piping, intercooler and odds and ends(being in Alaska, shipping is a huge cost), combined with my time and frustration would offset the price of the hi-flo kit.
I guess I should change the thread title lol
#88
I actually finished the plate like 2 months ago lol. I havent had a change to drill holes for the bolts or paint it. Good thing I kept the template to mark where the bolts would be going.
#89
Core support is shaved aside from the necessary holes. Wheelwells are done also.
Primer!
![](http://i31.photobucket.com/albums/c361/TruStinger/New%20Build/IMG_20110221_161408.jpg)
![](http://i31.photobucket.com/albums/c361/TruStinger/New%20Build/IMG_20110221_161434.jpg)
![](http://i31.photobucket.com/albums/c361/TruStinger/New%20Build/IMG_20110221_161501.jpg)
Should be doing the wet sanding and any bondo touch ups this week. Then paint.
Primer!
#90
Hi-flo kit came in, atleast most of it.
Went ahead and bought the Lunati Gold dual valve springs. Specs:
O.D. 1.306 inch; I.D. 0.676 inch; Max lift: 0.660 inch; Seat load: 153 lb/in @ 1.810 inch; Open load: 400 @ 1.150 inch; Rate: 379 lb/in; Coil bind: 1.100 inch
Should work with my turbo cam(228/232, .60?/.60?), and provide enough pressure that it can handle some higher boost.
#91
Things left on the "Need to buy" list:
3 Point SFCs
Comp Engineering Shocks
Strange Chromemoly Driveshaft
Boost, Fuel pressure and oil pressure gauges(possibly oil temp or EGT also)
Pushrods
Sway Bar
And my "Like to have" list:
Meth kit
Aftermarket fuel rails
2 step
3 Point SFCs
Pushrods
Sway Bar
Meth kit
2 step
#95
There a couple parts of this car that I am very proud of; the radiator support and the blowerbox block off plate. Both were spur of the moment decisions to be different, and both set me back a ton of time. Partly due to lack of knowledge, and partly due to being baffled as to what I was doing. Im glad I really took the time to do these, even if it was a huge pain in the ***.
The blower box plate is installed and looks amazing.
![](http://i31.photobucket.com/albums/c361/TruStinger/New%20Build/IMG_20110304_210849.jpg)
I used weather stripping all around the hole in the firewall to seal out some of the engine air from making it to the cabin. I thought about painting the bolts black so they wouldnt be seen but the contrast of the silver against flat black looked really nice.
#99
Dont have any pics but it was a HUGE pain in the ***. It took up alot of my time. There were about 15 spot welds and some of them were hard to see or feel. I ended up making a couple gouges in the firewall when I was pulling on the strip.
