APS Camaro Track Times!!!
Old Oct 5, 2010 | 10:38 PM
ttboydfw's Avatar
Default APS Camaro Track Times!!!
http://www.youtube.com/watch?v=-s2mwf-9CUo
This was at Ennis TX Oct. 2 2010
DA was 1828ft
1st pass
R/T ... .014
60' ... 1.599
330 ... 4.378
1/8 ... 6.714
MPH ... 105.18
1000' ... 8.741
1/4 ... 10.461
MPH ... 130.72
2nd pass
R/T ... .152
60' ... 1.555
330 ... 4.296
1/8 ... 6.665
MPH ... 103.78
1000' ... 8.719
1/4 ... 10.459
MPH ... 129.12
I think with the right air and track prep I could see low 10's. I did 6.50@106 in the 1/8 here in Abilene. So that tells me it can go faster. But now I think I have some valve train issues to work out.
Old Oct 5, 2010 | 10:43 PM
venom ws7's Avatar
Good run congrats.
More info on the setup please?
Old Oct 5, 2010 | 10:44 PM
02sleeperz28's Avatar
Nice...
Old Oct 5, 2010 | 10:50 PM
ttboydfw's Avatar
Originally Posted by venom ws7
Good run congrats.
Hope this helps
APS Twin Turbo kit @ 10 psi, 585 rwhp mustang dyno
Small turbo cam, PRC dual springs, titanium retainers
FLT Level 4 4L80E w/ Vacuum modulator
PI 3600 stall
Moser 12 bolt, 3.73's, full spool, aluminum cover, 1350 yoke
Drive shaft rated for 1000 hp
Weld Pro Stars, 325/50-15 MT Drag Radials, New MT front runners
BMR sub frames
Spohn chrome-moly LCA's w/ spherical rod ends - adjustable
Spohn drag anti sway bar
BMR adjustable PHR
BMR T/A
BMR transmission x-member
Competition Engineering rear drag shocks
Strange double adjustable front shocks
BMR tubular k-member
SJM manufacturing line lock / ABS delete
Dual 255 fuel pumps, FAST rails, rail mount regulator, 60 lb injectors
Alchy control meth kit
LPE 2 step
A pillar gauge pod w/ boost, trans temp, and wide band AFR gauge
LC1 wide band
Wolfe bolt in 6 point roll bar
5 point harness
Old Oct 5, 2010 | 11:09 PM
venom ws7's Avatar
It does help thanks for the info now crank the boost up and get that thing in the 9s.
BottleFedZ346's Avatar
Not bad at all!
Old Oct 5, 2010 | 11:20 PM
ttboydfw's Avatar
I think if I put her on a diet she could see high 9's
Old Oct 5, 2010 | 11:24 PM
MY99TAWS6's Avatar
Umm this is stock engine or forged .if forged what displacement.If stock don't crank that boost up much higher unless you like looking at broken ringlands.
Old Oct 6, 2010 | 11:04 PM
93camaro_zzz's Avatar
Very nice times! I am also wondering what motor you have this on? But you got a pretty nice 60'! I would also say a little less weight, and/or a little more hp and you have high 9's. Congrats again!
Old Feb 4, 2011 | 06:04 PM
ttboydfw's Avatar
Stock motor plus small cam, don't worry not messing with the boost until I go forged and LG turbo's.
Old Feb 4, 2011 | 06:06 PM
ttboydfw's Avatar
She weighs in at about 3800lbs, so she needs to be put on a diet.
