View Poll Results: Which wideband should I go with?
AEM UEGO
36
66.67%
Innovative LC1
18
33.33%
Voters: 54. You may not vote on this poll
Wideband ? AEM UEGO vs Innovative LC1
Which one is better and why? They both cost about the same on ebay.
LC1
Pros
Comes with logworks
Accurate
Uses the Bosch Sensor
Cons
Damned ugly bland *** gauge (Only reason I dont want it)
Does not match my gauge setup at all
AEM UEGO
Pros
Good looking gauge
Accurate
Cons
No Logging Software
Now I am running HP Tuners MPVI Pro so I dont think I need the logworks from the Innovative kit. Both sensors have the input wire for the HP Tuners.
The question I am wondering is is there a specific reason I should go with the LC1 over the AEM Model? Will the Innovative benefit me over the AEM model? Lemme know what you folks think.
LC1
Pros
Comes with logworks
Accurate
Cons
AEM UEGO
Pros
Good looking gauge
Accurate
Cons
No Logging Software
i got the innovate wideband.... i got the G3 gauge it doesnt look bad at all and close to matches the GTO speedo and stuff... also got the G3 boost to match should look good when they go in...
dont know what is better or worse....
lc1 install is much more involved.... aem is a bit simpler. But i do believe the lc1 is a great product..... if they could just get their problems ironed out.
Had the lc1 for a short time and loved it. Had the gauge that looked like most of autometers guages... It broke and they replaced it but i did not want to go through wiring it in again. I bought the fast and wished i never would have stopped using the lc1
not bad! i picked mine up from a ebay seller who had alot of em at bout the same price, jus a tad higher.i like that the o2 sensor itself is self calibrating, and cheap to replace! matches my tru-boost controller too
From what I hear you can fudge the software and hook your widebands data wire through another sensor such as the A/C sensor or the EGR Sensor then set up your values for the wideband under one of those 2 sensor PID locations. There are writeups on how to do it, here is one with pics:
http://forums.corvetteforum.com/c5-s...hp-tuners.html
I have run the PLX (****), the NGK AFX and it works perfectly ( I have three now), and I am also using the LC-1 on a project. I did experience some isuess with the LC-1 on the project. Realy I think the AEm, the NGK, and the LC stuff are all pretty much the same quality and reliability.
Nothing but problems with NUMEROUS Innovate products....Their wideband being the worst.
Switched multiple cars to the AEM and the problems dissipated. Plus we've done numerous test with the AEM's vs. the dyno and they have been spot on.
-W
-W
