Piston Oil Squirters
The Comp solution looks very good.
Kurt
It comes with 2 fixtures, one for cyl. 1-7 and one for cyl. 8. Here I'm doing cylinder 3. I have already drilled the hole then stuck the bit through to show the angle:
Jim
The only issues I saw with that style, was on the narrow skirted pistons LS uses, it would be spraying oil at the pin boss a lot of the time, and not the underside of the piston.
I will post up a thread about my new build now that I have enough to make it worth reading.
Jim
Kurt
If the galley based squirters are not an option in the LS6 block, what about drilling the mains and doing a setup similar to DeltaT's 421 block?
Chris
Kurt
Kurt
Are there any bulkhead style oilers that have the valve in them? I have read about some foreign (Asian) motors that have bulkhead style oilers with check ***** in them.
If I ran the LS9 oil pump, would I have enough flow capacity to support the open bulkhead style oilers?
Chris
edit: I found these. http://www.e30m3project.com/e30m3per...rs/squirt2.htm Turns out the older BMW engines had bulkhead style oilers which have a check ball in them to close off at low pressure (idle). They are about $30 a piece, but I would think they would provide some added insurance without hurting bearings.
Part# 400-050.
It's $393 and comes with the fixture blocks, the port drill bit, a tap drill bit, a tap, and 8 orifices. Just for comparison, the Kateck squiters are basically $400 (for the squirters) and I think they want $300 to install them.
I'm thinking the BLP kit would work fine for me if I run the higher volume LS9 pump (the guy at BLP pointed out that at low RPM it won't be squirting much oil....perhaps the orifice is really small?).
If not, I guess I could take the BLP kit, drill the bulkheads, then flip the block and install the BMW spring loaded orifices. Agree/dissagree?
Chris
Kurt
Inevitably I have to ask, "what is the real advantages of doing all of this?" While I certainly see a benefit of having cooler pistons and increased pin oiling, at what point does it really show a benefit? Is it something that a "hot street engine" would warrant or is this something reserved for high RPM/high boost/high HP? I can't see BMW, Volvo, etc. putting these things on their N/A engines (which they do) if they didn't make a major improvement in life expectancy of the engine. So, when is it really worth the cost/trouble/etc?
http://www.importcarparts.co.uk/part...chKey=squirter
Ive seen videos and pictures online, where people modify the conrod to allow more oil to end up on the underside of the piston. Not as functional as a jet, but certainly easier to achieve ?
ie, like this
or another variation
ie, like this
I'm "tempted" to find a cracked LS1 block so I could drill the main oil galley to prove whether or not if there is any way to make the "fancy" squirters work.
Kurt
Kurt
Kurt
