View Poll Results: Does the TH350 survive an 8.6X pass at 3800#?
Voters: 25. You may not vote on this poll
Can a TH350 survive an 8.6X 1/4 mile pass at 3800# in turbo car?
#41
We have a track out here that is the same way. The more they know you the more you can get away with. I say let th350 have it, its held up so far. Goota love those singal digit street cars!!! Good luck!!
#45
i agree that street cars dont have cages however im not against at least a 4 point hoop. done right they are hard to see from the out side and at least offer a little protection.
#47
I went to make another pass to see if it happened again and that's when I noticed that I may have spun a bearing. The car seems to be down 5-6 psi of oil pressure at idle. That's when I decided to throw in the towel and self medicate.
![Smokin](https://ls1tech.com/forums/images/smilies2/smokin.gif)
#48
After the 9.0 passes (4th and 5th), I started trying to crank up the power. It started bleeding boost, not exhaust pressure. It sounded like my BOV cracking open and shutting 2 times during the pass.
I went to make another pass to see if it happened again and that's when I noticed that I may have spun a bearing. The car seems to be down 5-6 psi of oil pressure at idle. That's when I decided to throw in the towel and self medicate.![Smokin](https://ls1tech.com/forums/images/smilies2/smokin.gif)
