what size wastegate do I need?
Old Jun 29, 2012 | 12:21 PM
  #61
KILLER-LS1's Avatar
Back to the OP's question:
From Turbosmart:
Big Turbo/Low Boost = Bigger Wastegate
Big Turbo/High Boost = Smaller Wastegate
Small Turbo/High Boost = Smaller Wastegate
Small Turbo/Low Boost = Bigger Wastegate
Low boost requires venting more pre-turbo exhaust, so you need a bigger WG to do that. I think a Turbosmart 50mm pro gate would work well. Its still working for me in higher boost areas as well. Id imagine if i was 25+ psi i might want to downsize. At a certain point, the backpressure has more surface area to push open the valve on a big gate, which is why you want a smaller gate with high boost.
hope this helps!
Old Jun 29, 2012 | 01:15 PM
  #62
JoshuaGrooms83's Avatar
define low boost?
like how low. obviously 4psi is low but what about 10psi? i have a 38mm with 7psi but if i uped it to 10lbs, should i look into a 44mm wastegate?
Old Jun 29, 2012 | 01:18 PM
  #63
KILLER-LS1's Avatar
Originally Posted by JoshuaGrooms83
define low boost?
you'll be fine with the same gate.
Consider that imports can be 50+ psi and diesels can hit 100+ psi. so generally speaking the LS crowd would be lower boost. I would call high boost 20+ for us
Old Jun 29, 2012 | 01:20 PM
  #64
ok sweet, wasnt looking forward to buying another gate lol
its gonna be setup rear mount style so was really wondering about this.
Old Jun 30, 2012 | 11:19 PM
  #65
Jammer's Avatar
This thread shows a likely cause for my overboosting. Will update
Old Nov 17, 2012 | 08:41 PM
  #66
pj5.0's Avatar
Originally Posted by TiAL
this is not
anyone know how to get a hold of this guy.. i need some welding done.
By Brett Foote | 2026-06-04 05:00:17
