how to plum turbo coolant lines
Old Nov 5, 2010 | 12:28 AM
383lt1impala's Avatar
Default how to plum turbo coolant lines
i am almost done building the headers for my impala project running twin gt35rs. how do i go around connecting the coolant lines to them? thanks in advance. btw are the threads 14mm?
Old Nov 5, 2010 | 08:30 AM
427's Avatar
427
Precision had a small line kit they sold for this a few years back. You should run one line high into the top of the radiator if possible with the other line low off the engine.
Kurt
Old Nov 5, 2010 | 08:58 AM
TracyRR's Avatar
when i had gt35r's, i tapped into the heater hoses and ran -6 braided lines to the turbo's. It worked great for me. Best of luck.
Old Nov 5, 2010 | 10:49 AM
adam205348's Avatar
APS recommends to run to the boss in the middle of the side of the block and then the coolant passage in the head.
Old Nov 5, 2010 | 11:19 AM
427's Avatar
427
The reason the lines should work better with one low and one high is the water will move when the engine is off helping cool the scroll section when the heat soak starts trying to burn/coke the oil in the bearings.
Kurt
Old Nov 6, 2010 | 08:23 PM
kurt do you perhaps have a diagram??
Old Nov 6, 2010 | 08:27 PM
adam205348's Avatar
Go down to step 34.
http://www.airpowersystems.com/corve...tall_guide.htm
Old Nov 6, 2010 | 08:51 PM
thanks!!!!!!!!
