Artic White 67 Camaro Forged Ls1 Iron Block Turbo Build *UPDATE 4/5/11 X-OVER WELDED*
#61
i did get a little done today, got the balancer off the cover off and tomorrow im getting a new front seal just cause i know ill mess the other off changing it, and i also need to find a balancer installation tool of some sort, maybe make one. and i need to know what the sensor is on the driver side block right above the oil filter. i have to either plug it or get a sensor to plug it if anyone knows the thread and size i would appreciate it.
#63
Ever Paint a car before? I just discovered this thread. Great build! I am doing a similar DIY build in my garage.
I bought a 74 camaro roller for 600.00 with no engine or trans. (really wanted a 67-69 but couldnt afford it). I am putting my Lq4 in it with edelbrock pro flo XT intake and 02 Z06 cam and S400 75 mm turbo. Car will have turbo 400 trans 3.73 gears and air to air intercooler with home made meth injection on pump gas, Street/strip weekend warrior car. I will control it with mega squirt for fuel and MSD box for timing.
Anyways your paint looks great! Did you use wookies how to paint dvd off the nasty Z28 site? I want to paint it in my garage too. I have never painted a car before. I will do everything myself on a super budget too. Did you ever wet sand it? May I ask how much ya spent to paint it? White looks great on that car. Did you want that color or does it hide flaws good etc? I know black shows everything. Sorry newb to painting. I will paint mine silver with the dual black chevy stripes on the fiberglass cowl hood and trunk deck.
Great build. Any advice on painting your own car for 1st time will be greatly appreciated.
Hpbob1
Hpbob1
#64
Hpbob1
Hpbob1
#66
Hi RNation001,
Thanks for all the advice on paint and body work. Yes that artic white looks really good and works on that car! From the pics it looks like ya did a great job for a 1st paint job. Especially in a garage! What version Mega Squirt do you have? Do you also have the stimulator? Is the mega squirt built yet?
I haven't started my build thread yet because my income has slowed way down due to the economy. So I haven't been spending on the car buying the parts I need to go forward. In this economy my build may take 2 years like yours! lol I figured when I can spend some money buying a lot of parts I need and really start moving on the car I will start my build thread. Here are a couple of pics of my 600.00 roller and LQ4 I will put a cam, turbo and intake on.
Hpbob1
Hpbob1
#69
Hi RNation001,
That sheet metal intake looks awesome and cool on your motor in the engine bay. That’s the main reason I will use the edelbrock pro flo XT intake cause it looks so cool and is basically a factory sheet metal style intake at an affordable price.
Sounds like your Mega squirt and stimulator is already assembled. Did you use it on a car yet? If so what motor and how were your results? How did ya like it, and how hard was it to learn how to tune it? Did you need to use a chassis dyno to tune it? Why aren’t you using it on the camaro? Just curious. Did you find out what version mega squirt it is? Thanks Dude!
Thanks Jordan national speed on the project comment. Yes I like this 74 camaro roller. Only drawback is it weighs a little more, but the turbo should take care of some of that! lol If things keep picking up at work I will start my build thread soon within a few weeks
Hpbob1
Hpbob1
#70
Forgot to check. Only used to start an old tpi 350 a few times then sold the car. Seems easy to use but the reason I didn't use it was lack of tuning knowledge. I could use one now but when I built it I wasn't as smart on tunin as now. Another reason is that it's a bank fire fuel injection system not a true sequential so the gas mileage won't be as good with it as a stock computer.
#71
ok well today was pretty good, managed to get most of the accessories mounted up, filled up the tranny, bled the fuel system and hooked up all the rest of the sensors. still dont have the radiator or serp belt but working on it. did get to start it up today tho. and found two leaks from my dumbness where i forgot to plug a couple galley holes in the block but after that it was golden, enough chit chat heres the vids, shitty sound ill get some better ones soon
First Start when we found the oil leaks
http://www.youtube.com/watch?v=5yIbbB3-0hk
Second Start was Smooth sailing
http://www.youtube.com/watch?v=n6T47FIH-5o
#76
