408 stroker
Old Nov 19, 2010 | 11:29 PM
ss408truck's Avatar
Default 408 stroker
Will a 76 p trim a good turbo to use on a 408 stroker.
Old Nov 19, 2010 | 11:40 PM
nossty1's Avatar
Nope.
Old Nov 19, 2010 | 11:41 PM
nossty1's Avatar
On a more serious note. Can we get some more details?
Old Nov 20, 2010 | 12:16 AM
ss408truck's Avatar
Tsp 408 stroker fully forged and blue printed 9.2to 1 compression afr 225 72cc heads fast 102 mm intake and throttle 1.7 harland sharp rockers meziere electric water pump ain't picked out a cam yet
Cam recommendations would be very appreciated.
Old Nov 20, 2010 | 01:09 AM
nossty1's Avatar
I really meant about the type of driving you will be doing. I would say an 88 would be about the smallest I would go on a motor that large. A small turbo like that will be good for a hi tq, low rpm street car but if you want efficiency your gonna need to step up to atleast an 88mm turbo.
Old Nov 20, 2010 | 01:22 AM
mwg2600's Avatar
You need a 114 mm with a billett wheel!!!!!!!!!
Old Nov 20, 2010 | 08:30 AM
rotary1307cc's Avatar
Ptrim on a 408 is funny
Old Dec 9, 2010 | 05:10 AM
lt1773's Avatar
Old Dec 9, 2010 | 05:11 AM
lt1773's Avatar
also for 408ci you need to run at least 88mm turbo
Old Dec 9, 2010 | 07:40 AM
Fireball's Avatar
turbo is too small.
Old Dec 9, 2010 | 12:43 PM
AES Racing's Avatar
Hate to sound like a broken record, our 390 would be a better choice then 408 with that head unit, and stronger. Its designed specifically for small frame turbocharger and D1SC, S-trim, novi 2000 etc
https://ls1tech.com/forums/forced-in...rankshaft.html
Old Dec 9, 2010 | 01:11 PM
DrTurbo's Avatar
LS1TECH Sponsor
A 408 would choke like a rock with a 76mm turbo.
You need something in the 88-91 range. Something like this would fit the bill....
Old Dec 9, 2010 | 02:05 PM
NemeSS's Avatar
theres your answer op
problem solved!
