1948 hp :)
Old Jan 12, 2011 | 01:29 PM
  #81
tirefryin_s10's Avatar
I know its a proprietary design but would you be willing to post some pics for us guys that are very intrested, If you do not want to post them for the world to see could you pm or email them?
Old Jan 12, 2011 | 02:52 PM
  #82
camaroandreas's Avatar
Look at page 3
Old Jan 12, 2011 | 03:10 PM
  #83
IMPATIENT 1's Avatar
i think there's still alil headgasket confusion, from what im reading in this thread, you DO HAVE TO MACHINE FOR THE PYRAMID RINGS, but not other machining for the gaskets right?i think a few guys in this thread think you can jus bolt down the hgaskets without the pyramid rings, and go out and lay 25+lbs to the motors
Old Jan 12, 2011 | 03:16 PM
  #84
Originally Posted by camaroandreas
Look at page 3
Any better pictures?
What is compressed thickness?
Any issues with them leaking water outward on the engine or anything like that?
What heappens when we need to pull the heads for a freshen up? Do we need to buy a whole new set?
Old Jan 12, 2011 | 03:36 PM
  #85
That is exactly what you do. This is NOT pyramid rings. Cooper gasket has rings that lays on the flat gasket surface. NO machining on the block.
Old Jan 12, 2011 | 03:39 PM
  #86
I can take some more pictures tomorrow. I think it´s 1.5 mm compressed thickness. They have never leaked on LS or any other engine. We have sold over 200 of these gaskets and nobody have had any problems.
I resurface the heads every 3:rd time you lift the heads. Then you have to shave them 0.1mm.
Old Jan 12, 2011 | 04:18 PM
  #87
Grr's Avatar
Grr
you know if you just made a complete post or ad about these and pay a sponsorship fee you would probably sell 50 sets in the first week or two. Everyone wants to buy and you arent providing the info well IMHO
Old Jan 12, 2011 | 04:22 PM
  #88
Where do i email for a sponsorship fee?
Old Jan 12, 2011 | 04:27 PM
  #89
now im confused i jus dont see a copper ring or gasket there in this pic, is the ring itself copper? i've seen no other headgasket pic in this thread.
Attached Thumbnails 1948 hp :)-ls1gasket1.jpg
Old Jan 12, 2011 | 04:30 PM
  #90
Not copper. Cooper gasket is the name of it. The loose rings are made of an material that expands with heat. You just put the rings around the cylinder bore and they fit perfect in the gasket that seals water/oil. No glue is needed..
Old Jan 12, 2011 | 04:41 PM
  #91
ohhhhh lol, sorry for the mix up then neat gasket setup no doubt!!
Old Jan 12, 2011 | 04:44 PM
  #92
I_Need_Land's Avatar
thank you.
Old Jan 12, 2011 | 06:21 PM
  #93
Waiting patiently!
Old Jan 12, 2011 | 07:59 PM
  #94
1kwikbird's Avatar
So is there a lip on the bottom of the ring, that fits down in the bore to seal it to the block?
Old Jan 12, 2011 | 09:31 PM
  #95
Grr's Avatar
Grr
Lets see if this is easier to explain.
The graphite gasket is used to seal the coolant and oil passages
This gasket has a very specific dimension for the ring, if its a 4.03" bore gasket the graphite has probably a 4.13" diameter.
Now the ring is 4.03" inside, 4.13" outside (or something like that) and will sit on top of the block, with the gasket firmly holding it centered over the bore. It physically cuts into the block/head so there is no gasket which could fail sealing the combustion chamber
Old Jan 12, 2011 | 09:37 PM
  #96
mikeyc34's Avatar
thats amazing gotta love the ls series
Old Jan 13, 2011 | 12:38 AM
  #97
NemeSS's Avatar
i think the gaskets are a great idea.
but i would like a further explaination info on how exactly they work and are installed correctly.
-correct-/available bore sizes and compressed values.
prices shipped for pair,etc
Old Jan 13, 2011 | 01:08 AM
  #98
You nailed it! But it´s a flat surface towards the block. It only cuts into the head. And the rings are made of material that expand on heat. So it´s the heads can lift a bit without anything happens.
Old Jan 14, 2011 | 02:53 AM
  #99
SS DNA's Avatar
Damn thats crazy power...
