Introducing the Aster Auto Spring Loaded Tensioner Bracket at Brute Speed!
#61
Bob i'm probably gonna pull the trigger on that used kit i told you about IF i don't go new from the get go. Really thinking about going that route with an F1A now and a standup front mount but may make that a future upgrade. Either way i have a buyer for the charger listed in my sig and once the check clears, i will place an order for the bracket. Hopefully you can get your 8 sooner than that but if not, you will have 1 more in line anyway.
Dave
Dave
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
#62
Hi Mike, if you can afford to do so, please order the Aster Bracket from us now as it will help to fill the eight order. It will also saves you $50.00, and you can always order the rest of the parts you need to go with your P-1SC head unit at a later date.
I did inquire with ProCharger after talking to you, regarding the pricing on their new 98-02 f body front mount intercooler option that is due to be released next month, and they can't nail down the pricing until they get all of their cost together from their suppliers. They're going to get back to me as soon as they can get the cost nailed down. Thanks Mike. Bob
#64
I hate to do that Mike, as we really need to get all the money up front. Since you have been a customer of mine since around 2002 I'll honor this price for you when you're ready to place your order. Thanks! Bob
__________________
#65
I should have the money for you by middle of next month.
#66
You're very welcome Mike. I had no idea if would make that much of a difference in your budget, that is awesome! Have fun in the Keys and have a Happy Anniversary! Bob
__________________
#68
There is a guy on here who has an Aster bracket and is running an F-1R, he says he has no problems at all with it. The F-1R has a max speed of 68K and I don't know how hard he is spinning it, but I wouldn't expect you to have any problems. Bob
__________________
#70
Here you go: Bob
04-19-2009, 08:53 AM #45
speedracer5532
Garage is empty, add now
speedracer5532's Avatar
Trader Rating: 7
Send a message via AIM to speedracer5532 Send a message via MSN to speedracer5532
Aster is a great guy to work with and his bracket setup is top notch. I am running his bracket/tensioner setup with a F1R and it seems to doing great. With the SDCE setup (running the SDCE 7.25 crank pulley) and a 4 inch blower pulley on a 427, I was getting 17.3 lbs of boost. Now with Aster's bracket setup and the ATI crank pulley (7.65) and a 4 inch blower pulley, I am seeing 18.3 lbs of boost.
__________________
John
2000 SS Camaro 6-speed
LSX 427 with F1R - 946 rwhp, 847 rwtq on 17.5 lbs
9.78 @ 150.52 with a M6 @ 3900 lbs race weight on 16.5 lbs.
speedracer5532
Trader Rating: 7
__________________
John
__________________
#74
The GM Corvette 2005 LS2 part number 89018052 water pump is the one to use for the Aster Bracket. This water pump does not have the large bell shaped pulley on it. The pulley needs to be pressed forward 11/32 of an inch, to properly align the accessory belt. Thanks! Bob
__________________
#75
Inspector12 currently is using one of these brackets on his F1R, but last I heard he has been waiting to get his clutch taken care of before he can really push it. I believe he was planning on maxing it out.
I don't know if there is anyone with the bracket using an F1C head unit. I know there are a couple F1A's running around though.
One thing of note is that there is a slight difference with the F series blowers vs the P1/D1 series with the amount of shims needed to get the head unit pulley to line up. The F series uses a single .1" shim instead of the .2" of the smaller head units. Inspector12 was having some belt issues, due to being almost a full tooth off, until we figured that out and resolved it.
#77
The pulley's don't come with shims when you order them.
The bracket though I ship with the shims so you don't have to hunt them down. I had a couple people that did not have the correct shims or sometimes no shims at all so I started packaging the bracket with the ones from Procharger.
P1 and D1 head units use two .1" shims for a total of .2" while the F series would only use one of them.
#78
Thanks for that info, I just may try this set up with a F1C - cheapest way out.
Wondering if would hold up to competition use consistently w/o slip running the F1C (class limited)? I know you have had it out for awhile, but I haven't seen anyone posting their success stories with the bigger units, track times or dyno graphs showing boost logs.
I wish Bob was still at EPP to run stuff on that Mustang dyno.
#80
__________________
