90* bends = restriction??
Old Nov 24, 2010 | 08:52 AM
lsxmalibu's Avatar
Default 90* bends = restriction??
Im looking to make my cold side more effiecient, I counted how many 90* couplers I have on my cold side, I have 4 of the
2.5" 90's (the small silicone bends), and the cooler has a 90 out on the front side....does this affect anything?
Old Nov 24, 2010 | 09:09 AM
TurboBuick6's Avatar
Of course the tighter the bend the more restriction you have. If some how you can do 45* bends with new piping will help out a lot and bump all the plumbing up to 3" that would help too.
Old Nov 24, 2010 | 09:22 AM
JAX04's Avatar
3" ftw
Old Nov 24, 2010 | 09:47 AM
Shearer's Avatar
Your thinking is sound. A few years ago I modded an intercooler to eliminate two 90deg silicone couplers coming off the core. It was a Honda that ran low 9's. Car picked up 2 or 3 mph by doing so.
Old Nov 24, 2010 | 12:08 PM
lsxmalibu's Avatar
ya I just put this togther as my first system not knowing if i would even like it, but i do and want to make it better.
Im thinking I have a guy to weld, if I could add 3" ends to my intercooler, then just redo the piping to 3"
Old Nov 24, 2010 | 12:16 PM
pwrtrip75's Avatar
http://www.pipeflowcalculations.com/...ecoefficientK/
Each elbow is equivilant to X feet of straight pipe.. Depending on radius, ID, and what not you should be able to figure the resistance pretty easy.
427's Avatar
427
Reduced restriction is always good!
Kurt
Attached Thumbnails 90* bends = restriction??-dscf3621.jpg   90* bends = restriction??-dscf3622.jpg   90* bends = restriction??-dscf3623.jpg   90* bends = restriction??-dscf3624.jpg
Old Nov 24, 2010 | 01:25 PM
lsxmalibu's Avatar
this is the cooler I have, got it from a local guy dirt cheap so i used it, should I cut off whats there and put 3" on the ends in a straight line, or start over? this cooler is 3.5" wide
