who's running a budget 347 or 370 shortblock?
Old 12-01-2010, 04:13 PM
AutomagicLS1's Avatar
Default who's running a budget 347 or 370 shortblock?
Just curious who all out there is running a nice little budget motor and how far ya have gone with it? My 347 is full of used parts from the oil pump, used stock crank, used rod bolts, rods, pistons, everything and still going strong plus sees several thousand miles of street action. I'm going to do a newer motor this winter most likely a 370 and keeping my 347 as a backup. Just seeing how far people have gone with one that's not outrageously expensive. Also your tips to keeping them alive.
Old 12-01-2010, 04:16 PM
slowlsx's Avatar
ive got a forged iron 347 in the works, used diamond pistons and h beam eagle rods roughly 9.7:1 compression. what rods and pistons are you using? and how much boost have you ran on your setup?
Old 12-01-2010, 04:21 PM
I've got used forged Mahle 4cc pistons and used Scat H-beam rods. It's seen easily over 100 pulls on 15.5 lbs on the street which is right where it runs out of fuel on my nearly stock fuel system. The car is making about 790 on that tuneup. I think it will lose a bearing before something catastrophic happens. The bearings in the motor were thrown in while the oil pan was off and no clearances measured Trying to find out how far this little clunker will get me
Old 12-01-2010, 04:56 PM
Hank Peabody's Avatar
Damn leave it alone and drive it forget the 370, 146mph is moving!! I saw you say 790 and thought "yeah right" then saw the mph, good job on that setup.
Old 12-01-2010, 08:13 PM
phatasp's Avatar
Damn, I hope my pos works out as good as your pos
Old 12-01-2010, 09:14 PM
itsjustaSB's Avatar
no **** good numbers im going to be pist if i cant pull those numbers with my setup u deff got things worken right
Old 12-01-2010, 11:11 PM
4bangermustang's Avatar
Building a 347 now. I might put hard blok in it. It will have main studs. Other then that nothing more then a good tune and I hope she lives for a while.
Old 12-02-2010, 10:26 AM
TRMIN8R's Avatar
My 370 has been in the car for over a year with no issues. Stock crank, scat rods, and wiseco pistons. Went 9.3@144 last year, bigger turbo is going on and shooting for a high 8 next year. Good gas and tune will keep it alive.
Old 12-02-2010, 01:52 PM
who assembled your bottom end down there? Did they do anything special? I'm not really concerned about a piston/rod failure i'm just worried about bearings lol
Old 12-02-2010, 11:14 PM
Restricted User
98Z28CobraKiller's Avatar
Iron 370 w/ stock crank, old set of Childs & Albert rods that the engine builder had laying around, LS7 lifters and a set of Wiseco pistons.
Old 12-02-2010, 11:17 PM
Mean87SS's Avatar
damn guys!!
Old 12-03-2010, 12:35 AM
tirefryin_s10's Avatar
Used diamond pistons
Used compstar rods
Used stock crank
Ported 317 heads
Used lightly ported ls2 intake
Twin mpt70 turbos
5.53@128 in the 1/8th and 8.62@159 @3325lbs on a 275 drag radial..... Do the math on that hp lol
Good old budget stuff!!
Old 12-03-2010, 02:26 AM
9 Second Truck Club
stock48's Avatar
What do you guys consider budget?
Iron 370
STD factory crank
Mahle flat top pistons, custom dished, Gas ported
Compster rods(had to resize out of the box)
ARP studs
Hand ported 317's
All truck acc's including intake
9.6o's@143MPH all boost in a 4850LB 4x4 truck 2nd trip down the track.
Old 12-03-2010, 02:56 AM
skinnies's Avatar
I think at your power level now you'll be fine, but when you turn it up to ~24lbs trying to make 1000-1100rwhp you are going to create a new list of problems, that is a whole different category.
Old 12-03-2010, 03:40 AM
02_ramair_ta's Avatar
Im putting together a little budget 370.
Used Scat H beams
Stock crank
Wiseco slugs
317s hand ported by me.. 2.02 int/ 1.60 exh valves installed
91mm turbo
Truck mani front mount setup..
I am thinking it should hold up to some power..
Old 12-03-2010, 03:56 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I put together my current 370 with parts from my "old" (only had like 5k miles on it) 346.
https://ls1tech.com/forums/forced-in...lots-pics.html
Old 12-03-2010, 01:04 PM
IWGF's Avatar
Solid Tech did it, I'm pretty certain TRMIN8R did that motor on the cheap and it's a monster.
Old 12-03-2010, 04:33 PM
LS1RedZ's Avatar
Yeah Im wondering what ppl think is a budget build? $$?
Im running a 370 with a stock crank and K-1 rods w/ Wiseco turbo duty pistons. Main and head studs.
Old 12-03-2010, 08:18 PM
98Camarod's Avatar
Used compstar rods
Used stock crank
Ported 317 heads
Twin mpt70 turbos
how much boost was that?
Old 12-03-2010, 08:58 PM
22 lbs for me max!
Quick Reply: who's running a budget 347 or 370 shortblock?
