Tc78 with 1.15 ar vs pt88?
#41
#42
9 Second Truck Club
got ya
FWIW i have a 370 with a l92 topend with a tc78 and 1.15
granted only running 8psi but i cant feel it roll over at all power wise up to 7k
I am looking to free up some flow too as i will be upping the boost and it spools almost too fast with the 1.15 and auto anyway
there was a 1.32 and 1.52 available at one time, but can't source one now
anyway, Justin at comp can fit up a 1.32 for a couple hundered bucks
thanks Josh
thanks Josh
#43
yes would be great to see documented real world results.
#44
ive got a TC76 .96 a/r interested in something that will let me spin to close to 7k..
worried i will run out of air at 6k or lower....
hope the bigger a/r thing helps might just look at something like the st80 or somthig..
#49
If you have intentions of forgeing the engine down the track and cranking up the boost, go the 1.15
if you haven't already bought the turbo get the tc78....
#50
for a 99% street car with T56 and stock bottom end i would be leaning towards the .96 ar , because you won't be running high boost, back pressure won't be such a problem, and with a M6 the quicker the spool between shifts the better.
I have the TC76 already with a divided 1.15, was going to trade for a .96 with someone on this forum.
Looking for a reliable 500rwhp thru a T56...
#58
What is the most anyone has put down with the TC78?
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#60
I did 675whp with my current setup. Can't wait to see the increase with a 1.52 ar housing and possibly a larger dp. I'm keeping everything else the same except the rear gear.
