Backpressure - Can big wastegates help?
I dont care how many wastegates you have it will only control how low you can take the boost, at x boost level your going to need a certain amount of pressure on the throat of the turbine to create the cfm of airflow needed to make the boost level.
BTW I do agree with your current pipe sizing theory......
Questions: if i wanted to change over to a t4 housing, is it a simple swap like my t3 was?.... i would of course change to a t4 flange on my hot side so the turbo would bolt up. Also, what size should i go with? i currently have a t3 .82.... what size does that compare to on a t4? the t4 options are .81 and .96. Which one should i get? Thanks a bunch! tracy
Awesome string of posts(thanks to all). This was some good reading. It sounds like you had great success with your approach. I have a similar problem, but with a very different set up. I have a stroked LQ9 block with a single Precision 78 mm turbo. This is a pretty small turbo for a 402 cu in motor. Unfortunately, it's the biggest one I can shoehorn in(this is all getting STUFFED into a 1990 Nissan 300zx twin turbo - call it revenge on the imports). Anyway, I can't go bigger on the housing. My logic was similar to your original logic. There's one twist to your approach that I'm interested in getting some input on. At the risk of being badgered for raising this dead horse to it's feet again; here it goes : In a compound turbo set up(turbos in series) there's a wastegate in front of the first turbo to set the discharge pressure of the first turbo(to a max psi). This gives turbo #2 a stable max inlet pressure. Turbo #2 then has a wastegate at it's inlet to set a stable max boost pressure(to the motor). My proposal(for my single turbo set up) is to use a wastegate right at the exit of the exhaust manifolds(2 into one wastegate) to regulate a stable max inlet pressure to my single turbo(just like the #1 turbo does for turbo #2 in a compound setup). Note that the first wastegate in the proposed system is monitoring the inlet pressure to the single turbo(not the boost pressure to the motor). It would be critical to set this pressure correctly such that the turbo had the correct spooling and max boost pressure(to motor). Note that if you set this too low it will take forever to boost and peak out a boost pressure that is too low. If you set it just right, it will be using the minimum inlet pressure to get your goal spool rate and max psi. This will naturally minimize the pressure required from the exhast manifolds(ie - wastegate #1 will be dumping everything that is in excess of the minimum requirement to reach your goals). I think this approach would minimize the backpressure at the exhaust manifolds(and therefore not choke the motor). If I've explained this correctly, you'll recognize that this approach is very different than just a "bigger wastegate", Please tell me what you guys think. Thanks!
its funny, i can sit on the computer for hours, but a book!? FORGETABOUTIT. LOL
