best intake
Old Dec 24, 2010 | 09:25 PM
lunati397's Avatar
Default best intake
Im in the planning stages for a turbo build my inspiration is 98cobrakillers setup but for the intake this will be in a third gen camaro not a 4th gen and I dont plan on using a stock setup
Now for some of you guys using aftermarket intakes what do you suggest for ease looks and performance I am using 317 heads on a built LQ9 bottom
Edelbrock proflow
edelbrock carb intake with elbow
stock
or what else is out there I dont want to spend in the 3000 range for custom sheetmetal setups but just curios to whats working good
Right now i like the proflow or the carb with elbow
Old Dec 25, 2010 | 07:07 AM
stevieturbo's Avatar
stock LS6 and TB will work perfectly and cost virtually nothing.
Cant really see the other two offering huge benefits for the money.
value for money, nothing beats the LS6
Old Dec 25, 2010 | 08:29 AM
MUSTANGBRKR02's Avatar
There you have it. Alot of people in the 9's and Mighty Mouse i belive is in the 8's with one. Although i think he has a 90MM TB on it.
Old Dec 25, 2010 | 08:41 AM
I think he runs a stock TB.
There is absolutely no need for a 90mm TB. There's a Ute in Australia running 8.2 at high 160's with a stock LS6 intake and TB. Or at least it did 2-3 years ago. Probably quicker now
Old Dec 25, 2010 | 09:32 AM
LS1NOVA's Avatar
Im using the Edelbrock single plane with Aarons elbow, just for a different look over the plastic stuff. Either of the Edelbrock ones will work fine.
Old Dec 25, 2010 | 10:41 AM
Josh@PremierAutosports's Avatar
With 317 heads run the ls6. My formula went 9.0 on pump gas with a ls6 intake and stock tb on top of some afr225's. Later on if you upgrade to some really nice heads then you can look into a intake to complement that.
Old Dec 25, 2010 | 10:42 AM
Fb0dy0nly's Avatar
cant beat the runners on the pro-flow for the price
Id take advantage of that extra room over the heads IMO
Old Dec 25, 2010 | 11:57 AM
As much as I'd like a ProFlo myself, I'm still not convinced the plenum itself is large enough to actually make it worth while
Old Dec 25, 2010 | 12:20 PM
lunati397's Avatar
Whats better ls6 or ls2. Because I can get a ls2 for free but I'll be doing custom fuel rails too so thats why im leaning to the proflo or Victor jr
Old Dec 25, 2010 | 06:02 PM
bad6as's Avatar
i have a completly stock ls1 tb and ls6 intake manifold. they have made 1k but there are better intakes for boost, the proflo if you can fit it, how much power is your goal?
Old Dec 25, 2010 | 06:19 PM
lunati397's Avatar
Im shooting 800 to 1000 hp it will be a fully built 370 317 heads with a pt88 truck manifold setup
Old Dec 25, 2010 | 06:20 PM
lunati397's Avatar
I can defiantly fit the proflo there is tons of room in thirdgens
Old Dec 26, 2010 | 08:05 PM
Monte4ever's Avatar
I'm building my F1A setup from the ground up in my 82 Monte and I chose the Proflow.
Old Dec 26, 2010 | 08:32 PM
020NN20's Avatar
look at camaro andreas.....he's makin well over 1000 on a proflo....I personally am running one and have no complaints at all, went 9.90 on low boost and a base tune....i can stick my arm clear to the back of that thing....the plenum i believe is plenty large.....they come as a 90mm TB opening, but being aluminum and quite thick, i'd imagine you could port the hell out of it as well....my opening is a 94mm.......
Old Dec 26, 2010 | 09:13 PM
tomz28's Avatar
LS6 stock TB here FTW
Old Dec 27, 2010 | 03:04 AM
Ever think that 427 and two ******* massive turbochargers has anything to do with it ? He'd make that sort of power regardless of intake.
The plenum doesnt appear that big. In general, the plenum would be at least the size of the engine, and it doesnt appear to have 6-7 litres of volume, although I may be wrong.
ET's are as much about traction as power. So using that as a guide can be misleading, and when a stock TB can easily handle 1000+, most certainly dont need 90mm+
Is all of your boost/intake plumbing 90mm+ ? If not, almost seems silly to run an excessively large TB.
I'm sure the Proflo is a great intake, and I'd like to be running one myself. But I dont believe it will offer much benefit over either an LS6 or carb style.
Although I'd hope it might free up the top end a bit.
Oddly, true back to back comparisons of any intakes on a boosted application seem to be very rare. Or at least rarely published.
Carrying this out on a turbocharged setup is pointless too IMO, as boost is too easily manipulated.
A test on a good blower setup, where the intake really is the only change to airflow would prove which is best.
Old Dec 27, 2010 | 10:56 AM
lunati397's Avatar
Someone else started another thread right after me and a new intake came up from holley hi ram which resembles a custom sheet metal intake and has alot of volume and nice design
