Possible procharged 370, help needed
Old Dec 27, 2010 | 02:42 PM
velox65's Avatar
Default Possible procharged 370, help needed
Posted in internal but got redirected here,
Looking to build my first FI engine and my goal is around 800whp but I'm not a stickler for numbers. The car is a ls swapped 96 v6 bird,will be a weekend/strip car
and here's what I have on hand.
6.0 block
243 heads
85 mm bbk intake+tb
Stock crank.
Now I know the stock crank is more than good but I'll need forged rods and pistons(what length and cc size) for running on 92oct(9.5.1 compression?)
Also since my car is a swapped car what procharger kit should I run(looking at f1-a)? A ls one for the motor but those style intercoolers may not work with my style nose?
And suggestions for fueling and so on, I know I'm overlooking Alot of things but I'm sure the pros will fill in the blanks for me.
Thanks
Travis.S
Old Dec 27, 2010 | 03:18 PM
LS1RedZ's Avatar
Yeah your stock crank will work just fine. I'd look into getting some Wiseco turbo duty pistons and some K-1/compstar rods. Somebody will chime in on what -cc piston you will need. Im thinking around -15cc with LS6 heads. Are you wanting to do a FMIC? If you can afford it I would go ahead and get the F1A. For fueling, I would call Lonnies or Nasty N8 and get his Stage 3 setup (easy install and comes with everything you need).
Old Dec 27, 2010 | 04:00 PM
velox65's Avatar
Yea I'd prefer a fmic if possible, even more so if I do the f1a, the rods should be 6.100" or 6.125? I'll give nasty a closer look I just skimmed over a few pages looking at prices.
Old Dec 27, 2010 | 09:56 PM
blue00ZZleeper's Avatar
Look up my build thread. Its like 98% of what you just described. Its under new build/combo 370/F1
Old Dec 28, 2010 | 07:45 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I'd ditch the 243 heads in favor of some 317's. That will help with your compression. I went with wiseco -11cc pistons and compstar rods. Your rod should be 6.125". My SCR is around 9.2 right now with my ~70cc heads (AFR heads that started out as 72cc, but they have been decked a few times).
Here is my build thread: https://ls1tech.com/forums/forced-in...lots-pics.html
Old Dec 28, 2010 | 08:14 PM
velox65's Avatar
I already have the 243s ported and all so I'd like to keep em and adjust compression with the pistons if I go with a 6.125 rod what are the specs for the pistons I need? New to that area.
Old Dec 28, 2010 | 11:21 PM
You check out my build? I'm running PRC stg3 243's with weisco-11 cc dished pistons like chevychad. My compression is around 9.5:1 or so. Callies compstar rods 6.125 length, stock crank, weisco -11cc dished pistons 4.030 bore, and more lol
Old Dec 29, 2010 | 07:20 AM
velox65's Avatar
Yea, yours is pretty much the same setup except a different car lol, are you expecting this to be a daily? Or what's your plan with it?
Old Dec 29, 2010 | 07:48 PM
It was going to be my DD but I ended up getting a 94 buick for 500 bucks lol. I DD'd my car right up until I got my buick. I still plan on putting quite a few miles on her. I built her to drive her...and hard at that...not sit at home all the time. I'm glad she doesn't have to be full time now because I'm a mechanic and it sucks getting into her all dirty. I had over 50K of hard boosted miles on my stock setup so I have high hopes for a nice, well rounded forged setup. I was going to run my D1SC but I ended up trading it for a F1. I'm hoping to be right at or over 800rwhp as well. Meth also made it decent for DD'ing it.
Old Dec 29, 2010 | 08:33 PM
velox65's Avatar
Yea I have a fiero for my dd now, can you pm me part numbers for the pistons and so on?
Thanks
