Update on group buy of larger exhaust housing for tc78
I have seen guys use 2 x 2 1/2" pipes through the tight spots then merge back to 3 1/2", not optimal but may help.
hope to make it fit.. but if it can i can go done to the 3 inch..
will just have to see
Ill be taking 2, one 1.15 and one 1.32 and plan on testing them back to back to back with the 0.96 currently on my tc76 with all the exact same rest of the car. starting with basic spring pressure in my MG which should be right at 4.5 psi, im in to see the difference in dyno graphs.
#34
We have 6 so far. I'm going to call today and get a price on the 6. Ill everyone updated today.
I to have had the pt88 thought. I would love to see those back to back tests. Pt88 vs tc78 with a 1.52ar
#35
Wow 6 damn. Yea be sure to update the price, I might have to get in on it if it gets much cheaper haha. Also when you call, ask if the new housings will bolt right in or if locations are going to change. And if they change, by how much. I'm thinking the 1.52 specifically.
#36
nice.. 6 lets see if we can get a few more!!!
hey HYDRO you think you could fit a 3.5 dp on the pass side?? i want to try to 3.5 and goin to put the turbo where the batt was...
aslo what batt did you run and did you DD on it?? i seen the pic of the really small one on the driver side thats what i want to do but need something i dont have to worry about driving as much as i want to....
#37
I think the 3.5" would fit but it would be TIGHT. Doable though I think. I might have to change my dump tube though bc that's taking up a lot of room down there.
I run this battery. http://www.streettunedmotorsports.co...ll_battery.htm It doesn't work so well when it's <40* out, but it was fine DD'ing the car April-October.
